ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   How to hook amplifier to head unit ? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/64062-how-to-hook-amplifier-to-head-unit.html)
TexasES300 Nov 11, 2002 06:51 PM
Hi guy. I want to hook up an amplifier so that I can get more bass from my es 300. The stock es weeter is pretty good. I am impress. I took out the head unit and I noticed in the back there is NO input/output RCA outlet where the amp wire can connect to.
How do most you guy connect the amp to your stock head unit ??
EGainer Nov 12, 2002 12:53 AM
you cant, you have to run it from the stock amp...
TexasES300 Nov 12, 2002 02:31 AM
so where is the stock amp....it is connect with the head unit ??
Thank for the reply
TexasES300 Nov 12, 2002 02:36 AM
Oh well, I guess I have to sacrifice my 2 rear 6 * 9 speakers and make it into RCA wire and connect it to my amp.
squarehat Nov 12, 2002 03:00 AM
Stock amp is under the passenger seat, it has a proprietary connection that's going to make hooking up aftermarket components tricky.
amrit50 Nov 12, 2002 06:14 PM
you don't have to sacrifce your rear speakers in order to do this. You do have to cut the wires, but you can solder new ones on, or you can just twist them on.
Tom_ES300 Nov 12, 2002 09:07 PM
What year is your ES300? Mine is a 2000 and the amp is NOT under the seats or in the trunk. I think it's to the right of the glovebox, in the dash.
Tom
EGainer Nov 13, 2002 03:36 PM
in the 92-96, the amp is under the passenger seat. in the 97 and up, it is behind the dash...
audioman15 Nov 25, 2002 12:57 AM
get a line converter from any audio store. buy some red t-taps from your local hardware store. the converter hooks up to you left or right speaker wires. use the t- taps to gain entrance to the speaker wires. also goig to need blue male connectors
