how to remove back seat 98 es
hi, i would like to know how to remove the rear seat in the 98 es 300 ... tryed to find something one internet but ... nothing.
tanks
tanks
pull up the bottom part of the seat. it should pop right out. Once it is out, you should see 4 screws holding the back down - one by each of the doors and the other two are towards the middle. Remove those four screws and you can take out the back. To take out the back, you have to lift the back up and then out. It is held in place at the top by two hooks, so make sure you lift it up first, and then out. good luck.
yes i need to remove it ... if i only pup the cover off , i cant remove the screws that old the sub in place .... and nobody know how i can remove the seat belt from the seat ?
if i want to remove the cover ( seems to be carton) how do i do ?
and do you know where i can buy those black pin ( like the one in the trunk that keep the matt in place)
Get the pins from the Lexus Dealer. They are cheap. So its not worth the time and effort to look anywhere else, in order to save a few pennies.
jpv7774
03-18-19 01:25 PM
