Location Engine Room J/B - connector side
1 Attachment(s)
My ES200 could not crank, I check the circuit and found high resistance from the junction box. This looks make the relay not working (6 volts only at start switch on ST2). Every node of the circuit works well, voltage connection, It may be the Engine Room J/B. I could not find where is the Engine Room junction box (not the fuse), is it just on the other side ? , I need to dismantle the the fuse box. Please help I attached a the picture for your easy reference
| All times are GMT -7. The time now is 10:37 AM. |
