Hesitation while accelerating
Recently its been doing it a lot....I think mainly when its cold but also does so when its warm.too. had the car checked out recently and they found nothing, any thoughts? It's a 97 with 147k miles and recently had a major service about 8 months ago.
Originally Posted by Alexbenz
(Post 7043003)
Cracks are relatively common as the rubber ages, and as you accelerate and the engine shifts positions, they open up and mess with your fuel/air ratio, causing the symptoms that you describe. Although not conclusive, also try accelerating and driving in reverse and note if it hesitates in reverse as well. Phil |
Might be an oil control valve? Not sure if the non vvti engines had those though
are you talking about when you hit gas it accelerates slowly at first but in about 5secs goes OD hard with a rapid push, even tho you didnt let the pedal go? my friend has such thing on his camry, cant fix it tho,if anybody knows whats up, let me knoe too
Originally Posted by PFB
(Post 7043140)
One relatively easy thing to check is to remove the large rubber hose behind the air filter Box (your model year may have 2, I can't remember) and carefully look for cracks in that hose. If you bend it slightly than cracks will become obvious.
Originally Posted by gray_es300
(Post 7043538)
Originally Posted by Yurka
(Post 7043565)
Test the TPS sensor if you got a glitch in it. You can search on youtube .
I checked a lot of stuff and didn't find anything, also it doesn't do it all the time. Taking it in for some minor work tomorrow but I'll ask the techs
(Post 7043140)
If you don't have any check engine lights, than the next thing I would check/change would be the fuel filters. Both the main fuel filter AND the one in the back.
Do a search on fuel filters, you will find additional info. There have been several posts on this topic. If you do have a check engine light, than what is it? Phil |
(Post 7056417)
Alexbenz any update on your car?
Cleaned out the maf and so far its good
Problem is still there, guess I gotta go back and see what it is.
Crazy thing is that I had my 98 ES300 hesitate once but didn't come back after that. Does it happen only when the engine is cold, or doesn't matter..?
Originally Posted by whooodat
(Post 7066162)
| All times are GMT -7. The time now is 12:05 PM. |
