Hi guys, been a while, so glad to be back in the forums... But down to business, I want to replace the relay integration control module in my 1996 ES300... I have removed the dash panel under the steering column, and can see the module, but was wondering how to go about removing it, because it's located under the plug for hooking up an OBD-II diagnostic tool. If anyone could point me in the right direction, it would be greatly appreciated. Thanks in advance, everyone!
If I remember correctly, just unscrew the ODB2 connector which should be 2 phillips head screws. Then for the relay you will need a SMALL flast head screwdriver to unhook the clips to pull the relay out.
Thanks for the info, worked like a charm. I've since replaced the module but no luck, the darn parking lights still stay on even when the car is off... I have tried removing the different fuses associated with the parking lights to no avail, and am considering putting in a switch for the parking lights so I don't have to open the hood and unhook the battery every time I park the car. I have been looking for more info since this problem began, but the relay integration control module is the only real lead I've gotten towards fixing it... Now I need to search for the wiring diagram for the parking lights so I can splice the wire to put a switch in the car near the dash somewhere... If you have any idea what else the problem could be, that'd be great, but if not, I do greatly appreciate your help! Have a good one!!!
