Father/Son project
Old Jul 14, 2011 | 10:08 AM
crisbmw's Avatar
crisbmw
Default Father/Son project
My Son bought a 92 es300 for $850.00, for a father/ son project.
Issues as follow:
1) Leaking Gas out the tail pipe. Stuck Fuel Injector.
2) White smoke coming out the exhaust, but no signs of a blown head gasket.
3) last but not least, can't get the computer to do a self diagnostic. when i jump the TE1 to the E1 connector the check engine and the O/D light just flashes. Oh, and where is the ecm located at. Any ideas on what could fix this would great full.
Old Jul 14, 2011 | 12:00 PM
EEngineer's Avatar
EEngineer
congrats on the pickup!
white smoke usually does mean blown head gasket. ur coolant is only leaking into the cylinders, not the oil.
if ur injector is stuck, the smoke would be black. so it's most likely not injectors.
if ur sure the pins ur jumping is the right one, the number of times the light flashes is the error code number
Old Jul 15, 2011 | 05:33 PM
crisbmw's Avatar
crisbmw
Thanks I think jk.I am leaning towards the computer. I was told the test ports were TE1/E1? It is getting way to much fuel. I can see it leaking where the exhaust manifold meet the exhaust pipe. I see it dripping on the heat shield.
Old Jul 19, 2011 | 04:40 AM
crisbmw's Avatar
crisbmw
EEngineer, I think you r right about the white smoke being a head gasket. Haven't seen any difference in the fluids tho. Once i figure out the fuel problem then I going to dig in to the smoking issue. maybe I can get it on a patch to stop the smoking cravings. lol
appsdba
RX - 1st Gen (1999-2003)
Feb 4, 2023 03:50 PM
EPayne42
25
Jan 27, 2015 06:05 AM
Raven2381
Sep 10, 2013 05:32 PM
UNCNOR
Jun 6, 2013 08:59 PM
94_soarer
Dec 14, 2008 09:05 AM
