ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   97 es300 strut bar. (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/567719-97-es300-strut-bar.html)
giovany24 Apr 28, 2011 12:36 PM
97 es300 strut bar.
im looking to put a strut bar on my 97 es300. i heard that the ones from the toyota solara should fit it. does anyone know the year that i have to look for so that the strut bar fits my 97 es300 with no clearence problems?
nine3es Apr 28, 2011 05:38 PM
here is one i have for sale, and another member posted there that it does fit the ES.
https://www.clublexus.com/forums/es3...wer-brace.html
giovany24 May 2, 2011 11:27 AM
do u guys know if a strut bar from an 01 solara will fit?? i can get one for 20 bucks from my local junkyard but i want to make sure it will fit with no clearence problems
PlatES300 May 2, 2011 11:52 AM
the oem strut bar from the solara is the only strut bar that will fit without any clearance issues.
giovany24 May 2, 2011 04:01 PM
i just bought it today but it seems as if the holes dont match up the the strut mount bolts.
giovany24 May 2, 2011 05:52 PM
3 Attachment(s)
here are some pictures of the bar i bought. but it seems as if it wont line up with the screws???? can someone help?
nine3es May 2, 2011 08:34 PM
take the nuts off and it will fit right
giovany24 May 2, 2011 08:57 PM
alrite ill give it a try tomorrow.
Ariyanna May 2, 2011 09:01 PM
1 Attachment(s)
it fits fine this is mine with it mounted
giovany24 May 2, 2011 09:56 PM
do i have to take off the little "c" spacer?
angmedic91 May 2, 2011 10:57 PM
I took my little C-spacers off, then placed the strut bar on, then put back the C-spacers, thightened down all the bolts, then finished. The strut bar you purchased should work, you may have bend the bar a little to get the holes to match up. I had to bend my bar a little, so it would match up and to allow the hood to close easily. The bar does snuggly hit the insulation under the hood, but no big problem. Just make sure you are not hitting the intake manifold or EGR valves. Otherwise the engine my vibrate onto the strut bar and cause annoying vibration sounds. Good luck.
giovany24 May 3, 2011 09:49 AM
how do u bend the bar? does it just bent by puttin some force on it or do a need to take it somewhere? thanks
giovany24 May 3, 2011 10:18 AM
didnt fit. anyone know of a way a can bend it??
nine3es May 3, 2011 10:54 AM
bolt one side on like it should be, then twist/bend the other side close to fitting. then you may have to unbolt the first side to get both on, then bolt them both down.
giovany24 May 3, 2011 01:17 PM
2 Attachment(s)
well i tried bending it, twisting it, tried everything but no good. seems as if the bar is a bit short and doest line up. im starting to think that the bar might be the problem. gona return it anyways
