Flush Or Not??
Old 03-25-11, 10:29 AM
ikant
ikant's Avatar
Default Flush Or Not??
I've had this discussion with several friends about whether or not to flush the tranny. My [main] mechanic says NOT to flush it for two reasons;
1. The AGE of the vehicle...['96 es300--295K+]
2. [because of reason #1] It will destroy the seals and lead to "rebuilding/replacing" the transmission.
Other mechanic suggests to flush it, since I have no idea when it was last flushed, despite it's age. So now I've decided to bring the question here as a "decision breaker". Flush transmission or not??
Old 03-25-11, 10:41 AM
funcrusher
funcrusher's Avatar
How do u know whether to change it or not? Mines been changed once by the previous owner. Good thread
Old 03-25-11, 11:24 AM
PFB
PFB's Avatar
If you never flushed your transmission before, than the process of flushing it now will release varnish and other contaminated which could destroy your transmission in short order. 100% new transmission oil will also tend to make the problem worse by it's cleaning action
You are much safer with a drain and refill where only about 40% of the oil gets changed. You can than repeat the process next year of you wish.
Don't look for trouble Don't flush.
BDSL
BDSL's Avatar
Use the SEARCH function.
Old 03-25-11, 12:10 PM
yeldogt
yeldogt's Avatar
Is this a car you just bought?
Is it the original transmission?
Condition of the fluid?
Personally -- if its the original transmission -- I would leave it alone and only add if fluid is low.
Old 03-25-11, 12:33 PM
funcrusher
funcrusher's Avatar
Why doesn't anyone ever have a simple YES or NO answer? I'm kind of scared to even mess with the fluid after hearing people say it can bring problems
Old 03-25-11, 01:40 PM
ikant
ikant's Avatar
Just purchased last month [Feb. 5th] from a dealer ["As-Is deal"]--I needed a vehicle immediately. According to mechanics the transmission looks the same (with new belt, air filter, and such)--I have no clue; this vehicle is my first. So, I have no idea about many things, just weighing suggestions from everyone. But everything points at, "Leave It Alone". Will have to check fluids to be sure before paying anyone [mechanics] anymore money.
Need to find a User's Manual. Thanks for the replies thus far guys--REALLY appreciate it.
Old 03-25-11, 01:43 PM
01LEXPL
01LEXPL's Avatar
drain & fill will never screw anything up <- mechanic #1 is wise.
Dude, i was considering this with 100k on my car, and chose not to since it can be more prone to leading to problems down the road.
Also, a drain & fill will cost you no more than an oil change, best part is you can do it a couple of times to get completely new fluid in there for less than what some of these 'flushes' cost.
Old 03-25-11, 01:48 PM
Coulter
Coulter's Avatar
My vote is no to a flush, just drain and refill.
I've heard both arguments for and against flushing, usually that flushing is safe as long as the transmission hasn't been neglected. I've also heard some mechanics say if the fluid is really bad and has never been changed, just leave it alone altogether.
At the end of the day, I think everyone would agree that a simple drain and refill is less risky than flushing. I personally don't think it's worth possibly destroying my transmission just to get it that little bit "cleaner" with a flush than a drain/refill.
Old 03-25-11, 03:54 PM
MikeLex
MikeLex's Avatar
300K? No flush. Sit back, relax and wait until it dies of natural causes...
Old 03-25-11, 04:57 PM
nine3es
nine3es's Avatar
im with Coulter ^
oh, and change the trans filter.
Old 03-26-11, 09:51 AM
ikant
ikant's Avatar
Thank you again guys--NO FLUSH is the way we'll handle this then--drain and fill. Feel much more confident now.
Old 03-26-11, 11:45 AM
Lexusfreak
Lexusfreak's Avatar
Cool
Another vote for a 'drain & fill' only.
Old 03-26-11, 01:44 PM
yeskay
yeskay's Avatar
lexus dealership recommends "drain and fill" only
Old 03-27-11, 10:15 AM
ikant
ikant's Avatar
Really?? That's really something which the "FLUSH-IT" people should be aware of. Wonder if any of the "Car-Care" places would follow that rule instead of RECOMMENDING it be done [$125].
Quick Reply: Flush Or Not??
