ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   RPM's while highway driving (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/559697-rpms-while-highway-driving.html)
lexusCBAZ Mar 19, 2011 12:17 PM
Hi. I have a 1995 ES300. While driving on highway/interstate the engine runs 4000 RPM's at 75 MPH. Is this about normal--it almost seems that there might be another cruising gear range in the auto. trans. When I press the ECT power button on console (for trans.) nothing seems to happen. Is that normal? Thanks.
worldforgo Mar 19, 2011 01:02 PM
Mine is barely at 3000 when at 75MPH. It sounds like your Overdrive isn't working properly. There is a button on the shifter, try pressing it and see if that helps.
ECT is something I have no experience with.
decypher Mar 19, 2011 04:41 PM
I had a similar issue but I'd get a 1000-1500 RPM jump after removing my foot from the acceleration pedal... My throttle cable had to much slack and it was hanging up on the heat/noise shield underneath the hood. (had to adjust the 2 nuts on the cable to make it tighter)
