ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Random OBD Codes (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/491133-random-obd-codes.html)
pookie1090 Mar 27, 2010 05:02 PM
Random OBD Codes
Hi everybody,
I am having the worst time trying to Figure out whats going on with my
1999 Lexus Es300.
The Problem:
When the car gets up to operating temp. I can feel the car hesitate, along with what sounds like a misfire. It will also flood the motor with gas that doesnt seem to be igniting. Then OBD will start spitting out codes like an ignitor malfunction along with the VVT malfunction. The car will also stop going into the overdrive gears after awhile. Yesturday on my way to work when it was a little cooler outside all the engine+VSC+VSC off light just went off by there selves and the car was running better. Then after driving today the problems came back.
What Iv checked:
checked all coils
replaced all spark plugs
new o2 sensor both
new temp, sensor
new Cat
(Everything Checks out to be fine)
Resolution:
Would i be wrong if i thought the ECM was going up?
ASG14 Mar 27, 2010 05:08 PM
ECU was gonna be my next guess......You can get one cheap from Ebay. Due to the fact the codes radomly change and go on/off themselves, it;s a good possibility.
pookie1090 Mar 28, 2010 03:33 PM
Thanks,
I took it to pepboys to see if they could do a deep diagnostic and they said they couldnt cause the Computer came up a Default so it was a waste of 97 dollars and now i have to set an oppointment with the dealer...
ASG14 Mar 28, 2010 04:31 PM
You spent $97 to get it checked? A used ECU costs $50......
