ECM replacement ES300
Old 03-14-18, 09:18 AM
  #31
wmj259
wmj259's Avatar
Originally Posted by wsrivers
I don't see any testing instructions from @tomf if someone could assist me with locating this it would be greatly appreciated. I can head over to Walmart to get a multimeter and hopefully resolve this issue. Thanks.
https://www.clublexus.com/forums/es-...olenoid-2.html
You will want to look at posts # 9,10,11,12, 23, and 24
Quick Note: You will want to open your glove compartment to do the tests, as it will help you test the connection from ECM to the Transmission at the same time.
Old 07-29-20, 05:47 PM
  #32
69torino
69torino's Avatar
Default Security module is separate?
Originally Posted by mitmaks
I wouldn't think that theft protection would kick in as this is your OEM ECU. Our 96es300 has some theft protection/factory alarm (same one you're probably talking about) and once I put in ECU there were no alarms,etc whatsoever. Car has been running great ever since.
I was told when looking for a computer for my 95 that the security module is separate from the engine module. If true, it makes things much easier.
Old 09-08-20, 08:21 AM
  #33
asalyers
asalyers's Avatar
how much did this guy charge to rebuild the ecm?
sbrady46
12
12-21-23 10:33 PM
mani6
02-18-21 10:05 AM
invictator
01-12-15 07:55 PM
Wert
06-24-08 09:46 AM
Quick Reply: ECM replacement ES300
