| ivory98es3 |
May 31, 2009 04:00 PM |
There are 3 screws to remove.....first is in the one covered by a color matching circle cover along the top of the door under the tweeter (you will also need to remove the tweeter cover by gently pulling it away while wiggling it).....next is the screw behind the door handle cradle, just pop open the little door and remove that screw and remove the cradle by sliding it back.....last one is underneath the door switches. You remove this by prying up the front of the panel for the switches, disconnect the molex plugs. Then take the bottom of the door panle and gently start pulling it away. The clips should just pop off and then just lift up and off the door panel.
