ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Radio auto-leveling volume (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/418546-radio-auto-leveling-volume.html)
mmatheny Mar 26, 2009 06:54 AM
Is there any way to defeat or adjust the volume auto-leveling function? It sometimes seems too sensitive.
justfixit Mar 26, 2009 07:43 PM
You cant adjust but you can disable using the sequence below
A. Verify the radio is on before turning the ignition key to the “OFF” position.
B. On the radio faceplate, push and hold preset number “2” and preset number “5”
at the same time.
C. Turn the ignition key to the “ACC” position while continuing to hold presets “2”
and “5”. (“ASL ON” will appear on the display.)
D. Release presets “2” and “5”.
E. Press the “CD” button to toggle between ASL “ON” and ASL “OFF”. When the
display reads “ASL ON”, the ASL function is enabled. When the display reads
“ASL OFF”, the ASL function is disabled.
F. Turn Ignition key to the “OFF”
mmatheny Mar 27, 2009 07:26 AM
Thanx! Is there a list of all the stuff like this for this car, like passenger seatbelt warning on or off?
MyfirstES Mar 27, 2009 07:22 PM
Justfixit: Thanks for sharing! I wondered if this could be shut off. It IS annoying! Especially during the first 30 seconds when suddenly the volume just suddenly goes way up.
Ariyanna Mar 27, 2009 08:14 PM
Does the 2000 Platinum series have this feature?
MyfirstES Mar 28, 2009 05:47 PM
Ariyanna, I *assume* it would as there was little difference from 00' to 01'. Try it out.
mmatheny Mar 29, 2009 05:37 PM
Yeah, I just thought mine was wacky - really low first 1-20 secs, then BAM! But, sometimes it works REALLY well - my buddy has a Corvette with it, even has a sensitivity adjustment, and it SUCKS!
adamyansam Apr 30, 2010 11:00 PM
Thank you soooooooo much!!!
at the same time.
Dude you are awesome. I called 3 dealers and they couldn't figure it out. I have a 2001 ES 300 and gonna try it. I'll comment after. Thanx.
