2002 ES300 with 112500miles DIYs??
Old 01-17-09, 09:19 PM
hoonami
hoonami's Avatar
Default 2002 ES300 with 112500miles DIYs??
TimingBelt
Waterpump
Drivebelts
Coolants were done at local toyota dealer past summer,
and i know i have to replace spark plugs NOW what other EASY DIY can be done at home? i do oil change and tranny drain/fill on regular basis... if i remember correctly there is no serviceable fuel filter, and no plug wires? how about pcv valve? is tranny filter neccessary? i also need to replace oil pan gasket, i've seen oil sweat from oil pan gasket. and how hard is it to reach back part of plugs?
thanks,
Tae
Old 01-21-09, 12:07 PM
hoonami
hoonami's Avatar
thanks cadeleon, what year is your es? did you have to replace plug wires? or do i even have one that's replaceable??
Old 01-23-09, 02:17 PM
tinkertoc
tinkertoc's Avatar
Tae,
I had the timing belt replaced at ~95K miles. The old one was like new, just a little shiny wear on the edges! Very robust design there.
I think the rear spark bank requires intake manifold removal. I did the fronts myself and had the local independent shop due the rear. Use good NGK plugs.
Have fun
Old 01-23-09, 09:01 PM
steviej
steviej's Avatar
Originally Posted by cadeleon
My es300 is an 03' your car is exactly the same even the 330 is the same just a slightly bigger engine displacement. I did not replace anything else besides the original/dirty/fouled out spark plugs. After changing them i felt a difference in the way my car was performing and the mpg went up. If you decide to do this to your car make sure you take your time on the ones in the back they are hard to get to.
taking the strut tower brace off helps get access to the rear plugs.
Another DIY project if not already done is the rear sway bar bushings. Two $10 items that will rid you of the inevitable clunk in the trunk noise. Easy to get at and only takes about 30 minutes.
Tranny drain and fills are easier than oil/filter changes. I used to do these every 15,000 miles. I actually have a pictorial write up burried somewhere on this site. I opted not to put in an inline filter because the drain and fills were cheap and easy.
Cabin filter is a piece of cake as is the air filter and brake pad/rotor replacement.
steviej
Old 01-24-09, 09:13 AM
hoonami
hoonami's Avatar
steviej
yeah... i always to my tranny drain/refill every 15k and your diy write up was awesome... thanks steviej!
and i've already changed pads/rotors past summer with genuine toyota parts as well as air/cabin filters.
now do you have write up on rear sway bar bushings? maybe a part# too?
how long did it take ya? any special tools required?
thanks,
Tae
Old 02-19-09, 12:41 PM
hoonami
hoonami's Avatar
Yes you can take off the sway bar and the intake manifold to reach the spark plugs in the back but it is not necessary. I did the job without having to do all of that.
really? thanks for your help.... wonder how it was possible without removing any of those parts... what year is your es?
Old 02-19-09, 01:30 PM
JSM1284
JSM1284's Avatar
I did my 02 ES300 plugs without removal of those items, Hope you have small hands!
Old 02-19-09, 01:54 PM
hoonami
hoonami's Avatar
yeah i've just changed it last night but trying to imagine how you guys did it without removing it... i am still trying to figure out with CEL codes now... sigh
Old 08-26-13, 04:42 PM
plkintulsa
plkintulsa's Avatar
Default 2002 es300 transmission filter change
I decided to drop the transmission pan and replace the filter on my 2002 es300. Draning is a piece of cake if you have 10mm hex tool. Taking the pan off and putting it back on is a royal pain. There are four pan bolts that are almost impossible to get to due to the clearance with the frame. Laying on my back underneath the car, it took about two hours to get it off and the same to get it back on. It didn't help that O'Reilly gave me the wrong filter. I am not sure if I really saved any money doing this myself. I would certainly do the drain and fill in the future before I try to replace the filter again. This hadn't been changed in 100k miles and the fluid looked like it was overdue.
Old 08-26-13, 05:42 PM
msekanha
msekanha's Avatar
Isn't the 4es a "filterless" transmission, I.e. Screen filter?
Old 08-26-13, 06:06 PM
brucelee1
brucelee1's Avatar
ATF-drain and fill, drain and fill.
Deathrow23
11-14-23 03:11 PM
Jbthompson
09-09-15 08:00 PM
mak89
Performance & Maintenance
40
05-08-15 08:19 AM
is250fsprt
11-18-14 12:43 PM
Skggyy
IS - 1st Gen (2001-2005)
12-31-11 11:19 AM
Quick Reply: 2002 ES300 with 112500miles DIYs??
