ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   lines across window (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/402110-lines-across-window.html)
Entourage7 Jan 10, 2009 07:41 PM
lines across window
i have a 97 lexus es300. i have 5% tinted windows all around. the passenger window always seems to streak with white lines. i have tried everything to get these white lines from stop coming. they are easy to clean off but they always come back in the same spot very slowly each time the window goes up and down. i was wondering if this happened to anyone else and if there is a way to stop these white lines from appearing. i have no idea if its becuase its tinted windows or if inside the window is dirty. i tried to clean the inside of the window that i guess u could say the window rubs against as it goes up and down but i never took off door panel to clean it very good. i used cue tips and ran them alone the inside track while the window was down. any suggestions?:sad:
HYPERBOY Jan 11, 2009 02:47 PM
ooooooooooooh man i have the same problem but with the front windows.
Megafast13 Jan 11, 2009 07:45 PM
I get that with my windows too. They always come back.
