95 window sealing leakage
After a rain or I wash my car (95 es300) after everything is dry and I roll down the windows (any windows) and put them back up water somehow is on the window from inside the door panel or something (perhaps the rubber seals get water in them?).
Is this common? How do I fix? Is there some kind of leaking/sealing issue with the black rubber parts on my windows? What do you all recommend I do? Thanks in advance. |
Bump Number One
ahh yes, welcome to the world of 13y/o rubber seals and frame-less windows.
Zymol has a product called "Seal" that is used to recondition rubber seals around windows/doors etc. I believe it has a stock BMW part no too if you cant find it online. |
Thats completely normal, for most cars. Water actually slides down the glass into the door panel, so you'd have to wait a couple hours for it to dry.
Thanks for the info I appreciate it.
I just wanted to make sure nothing was wrong and I can accept that it is normal. I will look into the seals thanks guys. |
| All times are GMT -7. The time now is 10:08 PM. |
