ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Those with IS300 wheels question (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/324484-those-with-is300-wheels-question.html)
kphu Dec 17, 2007 06:55 AM
Hey,
For those of you who has the IS300 rims on your car. It occurred to me the other day that the lugs are much shorter then the stock ES300.
Since I bought and using the shorter lugs, my question is if i got a flat and had to use the spare would the shorter lugs be long enough?
I sold 5 of the original ES300 lugs and still have 15 of them left so should I keep 5 of them in the trunk with the spare in case they don't fit?
Normally I would just take the spare out and try it but since its freezing cold outside, I figure it would be easier to post it.
Thanks,
Ken
Parker Gen Dec 18, 2007 03:30 AM
You most definetly want to stick with lugs that have a proper fit to your ES300. Which means, no shortcutting. Wrong sized lugs can cause your wheels to fly straight off under heavy manouvering. Also means, suspension, axles, drive shafts, disc brakes and rotors, exhaust etc can all be damaged in one shot. (seen it happen before Lol)
tuan92129 Dec 18, 2007 11:26 PM
The lugs are the same, except for the length...that means you won't be able to even put the spare on... well, that depends if you have the oem steel spare, or a full size spare.
BTW I don't recommend driving with the oem 15 inch with is17 inch spare for long...The diameter of the is wheel/tires are slightly smaller than the oem 15 inch rims/tires.
I kept 5 of the old lugs with the spare in my trunk so that i would be able to mount the spare tire.
kphu Dec 19, 2007 06:40 AM
Thanks for the responses. Good to know. Good thing I didn't sell the entire set of lugs. I'll keep 5 lugs and now have 10 lugs for sale.
I'm aware that there is a diameter difference. What I did was buy just the rims with no tires and bought 215/50/17. Stock tires was 215/45/17, I used a wheel dimension calculator online and with the 215/50/17 its less than 1% difference from the 15" stock. Technically this really doesn't amount too much since as the tires wear down the overall diameter changes.
