Couple quick simple questions
Old Jul 3, 2007 | 01:47 PM
2Tone93's Avatar
2Tone93
Default Couple quick simple questions
Couple things have gone wrong and cant seem to fix 'em myself and really dont wanna take the car in for something so minor.
Anyways
#1-Front seat no longer moves up/back or leans. I figured I blew a fuse, but I couldnt find any fuse for the seat motor, just for seat heaters. Anyone know where the fuse for the seat is or if I messed something else up?
#2-At the same time that went out, my gas cover popper button stopped working. I assumed it was the same fuse. If not, someone told me there was a manual release in the trunk, I looked today and was unable to find one.
The car is a 1993 Lexus ES300
Thanks
Old Jul 3, 2007 | 05:52 PM
MCG33's Avatar
MCG33
The trunk popper uses the dome fuse. I know this because I had to borrow that fuse to test out something because I had no bulb in the dome light anyway, and after I took it out the gas nor trunk poppers worked, as well as a couple other little things that I forget. As far as the seats I'm not sure, maybe start checking each fuse til you find a blown one.
Old Jul 5, 2007 | 11:32 PM
3000's Avatar
3000
If you can't see the manual gas door opener, it may be behind the cover in your trunk.
Old Jul 10, 2007 | 10:58 AM
2Tone93's Avatar
2Tone93
Thanks I'll check around there. What cover exactly?
Also do you know which fuse works w/ gas cover release?
Old Jul 10, 2007 | 06:01 PM
MCG33's Avatar
MCG33
They both work off of the dome fuse.
Old Jul 11, 2007 | 09:52 AM
3000's Avatar
3000
The cover is the gray lining/padding. The manual opener should be on the inside behind/close to the gas door.
whytry
Nov 26, 2021 06:23 PM
blally
RX - 3rd Gen (2010-2015)
Nov 13, 2017 05:55 AM
mossnojoke
Jan 10, 2006 03:30 PM
elclassico
May 2, 2003 08:59 PM
