ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   ES300: Replacing Cluster Backlighting Bulbs (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/272735-es300-replacing-cluster-backlighting-bulbs.html)
Veggies Aug 3, 2018 04:11 PM
Trying to figure out bulbs for cluster, need bulb size for indicator lights (Backlighting bulbs are 24s according to Tanninauto, but after calling them they refuse to give me the number for indicator lights {O/D, ECT, etc.} weird.)
Anyone know?
LeX2K Aug 3, 2018 10:22 PM
24? I don't know what that is. Some bulbs are either T5 or T10, also known as 74 and 168/194. Do NOT replace the airbag light with an LED this will trip an SRS code which is hard to clear. Best thing is to pull the cluster and have a look. Again a warning do NOT turn the key to ON with the cluster disconnected same deal you'll get an SRS code.
Veggies Aug 3, 2018 10:38 PM
Their reply here:
Originally Posted by TaninAuto (Post 8909345)
There are 8 bulbs for backlighting and 74 is not the right bulb. 24 is the correct bulb.
is correct about 74 being incorrect, as I pulled the backlight bulb out and and compared with a 74, the 74 is bigger. If you say 74 will work, I guess I'll try it for the backlights, and I'll see if I can find 168/194 for the indicator lights
Edit: indicator lights are definitely not t10 or t5.. those are way too big
LeX2K Aug 3, 2018 10:48 PM
T5 is about half the size of a T10. You sure T5 is too big? Or are these neo wedge bulbs for example 4.2 or 4.7 if so those are "grain of wheat" bulbs. Here's the part numbers for the replaceable bulbs for what it's worth.
https://cimg7.ibsrv.net/gimg/www.clu...3f1a2340c0.png
DLfpv Apr 18, 2019 01:31 PM
Having a really hard time getting the right side odo/trip and reset buttons clip unplugged. been at it for over an hour. anyone know what Im doing wrong? I tried needle nose to squeeze it and having no luck.
LeX2K Apr 18, 2019 03:02 PM
Why are you trying to remove them? Do they twist off?
DLfpv Apr 18, 2019 11:29 PM
They are a part of the trim piece that must be removed before the cluster can come out. I managed to flex the piece enough to get it to come out and just let it hang by the wires after trying to unplug it for nearly 2 hours. Not sure why mine will not unplug.
avhart Feb 23, 2021 03:03 PM
Hi and very informative. Will this procedure also work for the 93 LS400? My needles and warning lights are all working but no backlight at all.
Juju678 Apr 19, 2022 11:09 AM
Backlight for cluster
I’m still confused on how to change out my back lights. I want it where my speedometer is all blue basically I’ve gone and changed out the bulbs I thought would do the trick but that was only the shift gear bulbs. I drive a 2000 lexus es300 someone please help.
