ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   o2 sensor causing check engine light (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/208279-o2-sensor-causing-check-engine-light.html)
ssmoked Mar 27, 2006 11:19 AM
anyone experienced their O2 sensor malfunction causing the check engine light on? if so, did u have to use original factory O2 sensor or just any universal sensor from any auto store? thanks
GATO Mar 27, 2006 01:38 PM
Yes, check engine light comes on when 02 is out.
shop should reset light when work is complete
Tammy Mar 27, 2006 06:16 PM
Your dealer is correct, your engine computer likes the Denso (Toyota) brand...not much luck with the Bosch universal. Previous posts have experenced problems. Search on Denso O2
You might find this helpful... https://www.clublexus.com/forums/sho...ighlight=denso
