Need help with door panel
Old Oct 10, 2005 | 04:16 PM
Bluesman's Avatar
Bluesman
Default Need help with door panel
I was wondering if someone could offer a little help. I took the door panel off the driver's side door. I'm having trouble getting it exactly back in place. The trouble is coming from the four clamps at the top of the door. I'm not sure where they are supposed to go exactly. The top of the door panel is sticking out too far.
Old Oct 10, 2005 | 05:01 PM
3rdelement's Avatar
3rdelement
roll down the window. then set the top clamps close to where they should end up then push down and in....the tweater cover also gets in the way. i forget if you are supposed to remove that first before reinstalling the panel....BEST OF LUCK
Old Oct 14, 2005 | 01:00 PM
Bluesman's Avatar
Bluesman
I managed to get the door panel back on properly. The last time I tried it, it was sunset. Hence, I guess I really coudn't see how the top clamps should fit. I took another look today and saw that there is a bar on the top of the door panel that needs to go behind all four clamps. The clamp closest to the top right hand corner is the toughest. The speaker makes it a little tough to get it in there. Regardless, I'm glad I know how to do it now. I was able to finish my latest mod.
TWG1160
May 3, 2018 05:06 AM
JBLUR
Apr 13, 2014 07:48 AM
1sxyrxy
Feb 9, 2006 05:34 PM
bigvtwin
Jun 23, 2004 08:34 AM
