Rims Sizes???
Old Jul 12, 2001 | 09:56 PM
cialz's Avatar
cialz
Hey guys
what are the offsets and lug nut bolt patterns for our cars
also will 19x7.5 rims rub on our cars??
thanks
how bout 18x8
Old Jul 13, 2001 | 07:03 PM
lobo's Avatar
lobo
Default rim sizes
Whats cialz whats cracking the bolt pattern for rims for an ES is 114.3 x 5 offset depends on the width of the rims I have 18x8 with a +40 offset and in is perfect I had the rear inner fender lips shaved because I just lowered my car 1.6 inches and it gives ne way more clearance no rubbing as far as 19's ya 19x7.5 will fit on our car just make sure you get at least a +40 offset, 19x7.5 with a +40 offset should not give you any rubbing problems If you do go 19's your tire size will be 225/35/19 I wouldn't go 235 width because you might rub cuz it would be too wide I used to have 235/40/18 on my car and it rubbed even with the lips shaved in the back I have 225/40/18 yokohama paradas and i really happy with the 40 series tires are the lowest I would go on my lex because it is an every day driver I mean the ride can get pretty rough at times and you have to very careful over bump and dips etc. but I still retained a little ride comfort, so 35 series tires would be much stiffer ride but If you don't care about ride comfort anf you can a 19 inch rim that will fit go for it just really think about want you really want and remember 19 inch tires and wheels cost a lot more than 18 inch tiresand wheels my yokohama paradas are only $138 a piece on www.discounttiredirect.com so check prices on 19 inch tires and wheels and 18's also and see what makes more sense let me know if you need any more help be glad to help ya let me know how it turns out. -lobo-
Old Jul 13, 2001 | 11:02 PM
cialz's Avatar
cialz
thanks
ISALEX
Oct 14, 2009 07:05 PM
jdmwongsta
Oct 25, 2008 08:23 PM
cali_lexus
Nov 4, 2007 08:02 AM
IIJZSC300
Sep 14, 2005 11:12 AM
