ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   Heat Overload? (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/172230-heat-overload.html)
JMny2004 Jul 26, 2005 08:07 AM
Heat Overload?
So it's been really hot where I live (SC). Yesterday the temp. was about 100, and as I was driving home from work I got stuck at a red light for about twenty minutes since traffic was so backed up. Anyway, first the radio started to fade out, then turned off, then the A/C started blowing really weakly. Finally, the battery light came on. Once I accelerated the problem went away, and I've had no problems since. Do I need a new battery, or is this just something that the heat caused? Any advice appreciated.
mcelligott Jul 26, 2005 08:14 AM
Heat can really affect the charging and cooling systems in your vehicle. That was your alternator struggling. If it continues to do that, replace it. I had the problem of my other car (eclipse) starting to overheat at traffic lights due to the heat, so i added some coolant and it was ok. You'll run into stuff like that through august with these temps.
