LLS reworks the ES climate unit.
This customer wanted the factory colors back in, but I still think it turned out beautiful with the 14 volt bulbs in there. The screen is very bright
The Es are seemingly just as easy to do as the Sc (not that it is super easy, but you should try it on a different model!) So we are going to add it to the store and ES bulb replacement will be available officially. We've done around 20 ES units and seems the demand is increasing, so we are ready to advance.
I was surprised to see the buttons on these turn out almost white, with just a hint of blue.
http://www.lextech.org/osCommerce/
The green LCD screen looks a tad lighter than the stock version, and I too am amazed by the white backlighting on the control buttons. Not bad at all
Just a couple questions: Is 14V the standard voltage for the stock bulbs, and do you use your own specialty bulbs for replacement?
The bulbs are 14.4v ultra high output and are brighter than stock, yet ride above the alternator's output potential so they can never be destroyed by voltage spikes from turn signals and brake indicators...... like the original bulbs are after years of being spiked.
ESchris
Jan 20, 2004 03:41 PM
