Looking for a good strut bar
ive been looking at strut bars front/rear for my 95 es300, ive seen the weapon Rand other brands, which would you guys recommend, i need one for the rear but havent been able to find one anywhere, anyone know where i can find some???
Whiteline rear sway bar for the 92-96 Camry should work:
http://www.ctmotorsport.com/store/sc...?idproduct=104 |
Re: Looking for a good strut bar
Originally posted by MoreMGD32 ive been looking at strut bars front/rear for my 95 es300, ive seen the weapon Rand other brands, which would you guys recommend, i need one for the rear but havent been able to find one anywhere, anyone know where i can find some??? Weapon R = garbage. |
flipsise909, you seem to be pretty knowledgable on performance parts. what do you recommend for a strut tower/sway bars :D
sweet sig gato!
Originally posted by el gato flipsise909, you seem to be pretty knowledgable on performance parts. what do you recommend for a strut tower/sway bars :D MCV20 97-01, you can use the TRD Rear Sway for the Camry/Solara or Whiteline. I wouldn't recommend the front sway for the ES simply because it's a front heavy FWD car. You will only make the understeer worse with a front sway bar. Just stick with a rear sway. Tower bars, the TRD Strut Tower Bar designed for the Solara will work on any MCV20 chassis vehicle i.e. Camry & ES300. That's your only choice for name brand. Keep in mind, with any front strut bar added to the engine bay, you have to cut into/modify the hood insulation in order for it not to rub on the bar when it's shut. |
even with Z rated tires?
just got my front strut bar in the mail today, i need to order the rear strut bar soon.
How do i install the strut bar? i know there are 3 bolts on the strut tower, and obviously i have to unbolt them but, do i need to do anything prior to unbolting these? i wont F*** up my suspension just leaving the car parked w/ the e-brake on (i dont have to jack up the car or anything?) |
| All times are GMT -7. The time now is 12:54 PM. |
