What do you guys think? (tailight mod)
Very clean install. I think some of the SC300/400 forum guys who cleared their tails did the flourescent light diffuser mod as well to clean it up and spread the light better.
Originally posted by mr_lex300
Were the same properties used to get the tail lights apart?
put in oven etc? then remove the orange insert from the inside??
I would definitely keep the tail mod. Not only does it help with that what I think dull look of the current ES tails, but it truly does look badass. Do you have your fronts cleared too? and what about the clearcorners?
hey 3rdelement.. i don't think he use anything. he just took out that orange pieace... my rear light are cracked on the side..so i was checking it out.. there is a orange pieace in there that you can pull out.. after the orange, there will be a white layer..
Question:
"Did you open up the lights and bonded clear plastic material to the tailight lenses?"
"Please tell us how you did the "new" mod! Is that a jeweled texture tape?"
Answer:
"The "new" look is indeed an extra peice that I placed inside the tailight. I used the cover from a defunct lighting fixture that I had lying around and band sawed a strip that fit. I took the car outside in the sun today, and I was suprised how nicely the sunlight caught the inserts. "
Answer:
mod done. turned out fairly well, but this is a hard mod. I ended up cracking a couple pieces even though i took my time and was really careful. A lil superglue though seems to have fixed the problems. I was able to get pictures, but my sony camera stopped working. Ive sent it back to sony for repair. so when it gets back i can post some pics. If i can borrow a friends camera i'll post some images.
