ClubLexus - Lexus Forum Discussion (https://www.clublexus.com/forums/)
-   ES - 1st to 6th Gen (1990-2018) (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018-179/)
-   -   I hurt my es, help (https://www.clublexus.com/forums/es-1st-to-6th-gen-1990-2018/103015-i-hurt-my-es-help.html)
Stefwilli Nov 26, 2003 09:03 AM
I hurt my es, help
I was trying to do the weapon R intake yesterday. I took off the air box but it was still connected to the MAF sensor so I needed to disconnect it I thought. The MAF unit has the sensor built in with 2 screws holding it in place and what I didn't know is to disconnect the sensor you have to pull out the little pin, then pull out the wire from the sensor. What I did was took the little screws out and pulled the sensor from the unit. Not a smart move. So I had to buy a new MAF unit and I got one from a 93 V6 camry out of a junk yard. I hooked it up and the car still won't start. I don't know if its the part or the car guys, all I know is that I got fuel but I'm not getting spark to the wires. Does this part have anything to with my ignition system?
