2011 CT200h Intermittent Wiper not working
5th Gear
Recently my 2011 CT200h intermittent wiper function has stopped working. I can move past it for slow and rapid wiper function. If I push the the column I can get a single pass to work. I would like to fix this myself and not get hosed by the Lexus dealer if possible if it is something easy. I see the mention of a relay switch malfunction. Where is that located? Can I clean it or change it? The wipers otherwise appear fine. Is there a part number? Thanks for any help.
Hi, getting the same problem, initially I swapped out the stalk and the problem still persisted... hoping that someone knows if it is a relay ( where is it ?) or the fuse . Thank you
I found it - some more helpful links on where the Relay
Lexus CT200h Intermittent Wiper Relay Replacement Costs (yourmechanic.com)
