Go Back  ClubLexus - Lexus Forum Discussion > Lexus Model Forums > CT 200h Model (2011-present)
Washer fluid leaking on RH side, when headlight washer is activated. >
Old 03-23-19, 02:32 PM
Aisin
Liked 0 Times in 0 Posts
Default Washer fluid leaking on RH side, when headlight washer is activated.
Hello everyone, glad I found this forum.
My friends 2012, CT 200h is leaking a good volume of washer fluid from the RH/drivers side, that exits the vehicle from the bottom of the RH front bumper cover when the HL washer is activated. LH side functions just fine, and w/o leaks. I have never worked on this vehicle, so I'm wondering what might be a common cause of this... Loose/detached hose slipped from a nipple, cracked hose, cracked pump assembly, broken/loose clamp...
What is the procedure to inspect this area for the problem? Would the bumper cover need to be removed, is there an access point/port to conduct an inspection and repair? Thanks for your time, it's appreciated.
Aisin is offline
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
© 2019 MH Sub I, LLC dba Internet Brands
We are a participant in the Amazon Services LLC Associates Program, an affiliate advertising program designed to provide a means for us to earn fees by linking to Amazon.com and affiliated sites.
  • Ask a Question
    Get answers from community experts
Question Title:
Description:
Your question will be posted in:
