Has anyone swapped the turn signal flasher relay on a 17?
I've been reading about replacement flasher relays for running LEDs in the turn signals. I've done the swap on my other car. But I've also seen that relays like the TapTurn are only compatible with the 11-14 model years, coinciding with Lexus adding tap to change lanes in 2015. However, parts diagrams show that this relay remains on the 15-17.
Has anyone successfully changed this relay with the LED compatible one on a 2017? I'd like to avoid resistors if I can.
Does anyone know the location of the Turn Signal Relay on the CT? I thought I found it under the dash but it was Green in color and turned out to be the Brake Lamp Relay instead???
It's almost impossible to reach. I researched it on a youtube video but it's at the top of the dash...you'll have to reach around blind up there to find it from the driver's side footwell. Easier thing to do it turn the signal on while you're searching and feel for the relay.
