Fog lights on with only DRLs CT200h
Hey guys I'm new to the forum. I've done just a few mods to my '14 CT and I had a question about my lights. I would like to know if anyone has wired a mod to have the fog lights on with only the LED running lights? I would like to hear all options available! Diagrams would be wonderful. Thanks in advance!
You can easily do this if you manually install a fog light wiring kit w/ switch (about $15 on ebay) and run it to your interior panel where the square buttons are. Maybe I'll do this eventually and create a DIY. You'd just bypass the factory fog switch on the stalk.
I was going to bypass the stalk and add the wiring harness with dash switch but I'm interested in what you've done. I don't need a diagram or anything. What wires did you work with?
Thanks.
it's probably just a matter of jumping the relay somewhere. the good thing about my solution is it would allow you to do an HID retrofit on the fogs
anyway--- another thing. i want to figure out how to prevent flash-to-pass high beam (pulling the stalk) to prevent low beams from triggering. if anyone can figure this out, please let me know. probably a similar solution of jumping something somewhere. (or preventing something from being jumped)
