How long in EV mode
How long in EV mode
In bumper to bumper traffic I switched to EV mode. After a few miles, it automatically kicked out to eco mode, looking at a depleted battery display. This was my first time & wondering if it's normal for first time
I just drive in Eco mode and try to keep the green "Ev light" on in the instrument cluster. As long as you keep your foot very very very light on the gas you can stay in pure Ev much longer and you can drive a bit faster than the useless 'Ev mode.'
You also have to turn the heat down and ac off as the engine will turn on more often.
When I get off the highway at night I can drive to my house which is 2.4km or 1.5miles away completely in EV. I have to take off very slow as it takes about half a mile just to get up to a somewhat normal speed on flat ground. I can only do it the whole distance at night because I find I have better results if I stay at about 20-25 m/h, (which pisses off other motorists in the day time,) but where there is a bit of a downwards slope I can get up to 40m/h. It reminds me of riding a bike because even the slightest slope that you don't notice in normal driving, you notice!
I recall reading that the battery in the Prius (same as the CT's) will do 1.6 miles max.
For whatever reason, Toyota decided to make this ev button almost pointless.
The 04-09 North American Prius' didn't come with the ev button, however everything was there to add it. So I made mine turn on by holding the cruise control cancel button for 5 seconds.
It worked very well. Would let you go up to 25 mph, would let you enter ev mode when you first power the car up. And could go a fair distance on it.
But, the CTs is useless.
Won't let you power the car up and enter it as it wants to warm it up (unless it's warm outside or the car was just parked).
I always get "excessive speed" when going slow in parking lots (kicks out at about 12 mph).
And the distance is much less.
I'm glad I didn't pay extra for it, or take the time to do a install to add it, because it would be a total waste of money and time.
Living in Athens Greece I am lucky to get 0.6-0.8km max, if the engine is warmed up, in EV mode. Greek drivers typically go insane if anyone in front of them is driving slowly, so its rare I can get to the full range before someone tries to ram me because of slow speed. Lexus should do better next time...at least with rear "I am in EV mode so don't honk" displays or something more Bond-like, reverse firing nail dispensers... .
Do some reading on the "EV" mode ... it's actually more costly to use vs leaving the car in normal mode. The car has to turn on the motor to recharge the battery -- so you end up using gas and not getting any propulsion out of the fuel.
I wish the CT had the more accurate display of the Prius -- the engine is running briefly.
When you are coasting in normal mode -- the car benefits from regenerative braking.
I use EV mode when I want to reposition the cars -- that way I can move it without the engine. Depending on the temp it may or may not engage.
For max MPG, just pulse & glide..
