CT 200h Model (2011-2017)
Gas Tank not empty when gauge says so!
Old 04-20-12, 03:40 PM
Pwork
Pwork's Avatar
Question Gas Tank not empty when gauge says so!
Just had 5000 mile service. Gas gauge indicates empty and range indicats 20 miles or less, yet when I fill the tank it takes just 8 gallons (out of a rated capacity of 12). Service guy says, as I expected, "that's normal, they all do that". Extra points to him for making up a new Federal regulation that says compact cars (!) must have substantial reserves when registering empty, but, really, one-third of the tank? Any other experience with this?
Old 04-20-12, 03:55 PM
DBV1
DBV1's Avatar
Same thing happens on mine. Although mine was about 8.7 gallons and the light went on. Wish it was a little more accurate.
Old 04-20-12, 06:10 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
Every car does do that... its just how it is... most cars will show empty with 3-5 gallons remaining, the light turning on with 2-4 gallons remaining...
He said it because he sees it and hears it all the time...
Old 04-21-12, 12:38 AM
evicfinite
evicfinite's Avatar
also engine won't start if it runs out of gas... the electric motor will malfunction, so this is a precautionary thing that's implemented.
anyways how about you drive it for those extra 3-4 miles and let us know how it goes...
Old 04-21-12, 12:52 AM
gyung
gyung's Avatar
I'd be pretty nervous if my car's fuel light came up at two gallons left - because if you're in the middle of nowhere... good luck!
Old 04-21-12, 04:57 AM
DBV1
DBV1's Avatar
Interesting - every car I have owned always came extremely close to calculating how many miles until the tank is empty. This one just happens to be way off in calculating how long it take to get to empty. Must be ultra conservative.
That is one disadvantage of this car so far, while the gas mileage is really good, the tank is so small that you have to fill up more often than other cars I have owned.
Old 04-21-12, 04:52 PM
rdalemerce
rdalemerce's Avatar
My 2010 Prius was the same way. Since the power train is essentially the same, I'm not surprised that the fuel management systems are probably the same too.
The only difference that I've noticed is that I get fewer total miles to the tank - so I don't "push" it as far as I did with the Prius. I try to fill up at ~400 mile mark if I'm in town and less chancy if I'm on the highway.
Old 04-21-12, 07:33 PM
raptor22
raptor22's Avatar
It is normal. i don't have a CT, but i have an IS. The gas light comes on with about 30 miles of range left. And when the range says 0, there's still about 2 gallons left in the tank as reserve.
Old 04-23-12, 02:18 AM
Doublade
Doublade's Avatar
yeah just like everyon stated its a safety for the reserve haha
Old 04-23-12, 12:12 PM
OutlawTita
OutlawTita's Avatar
So the fuel light comes on when you have 3 gallons of gas left in the tank.....you know that you can go at least 100 miles and probably at least 120 miles assuming 40 mpg. I figure at 80 mph I should get at least 38 mpg which is still well over 400 miles per tank. Maybe you need more info....but I am fine with a 3 gallon warning.
Old 04-24-12, 06:54 PM
Risi
Risi's Avatar
How often are you fill up?
Old 04-24-12, 08:44 PM
Trexus
Trexus's Avatar
Topic has been discussed heavily in this thread...
https://www.clublexus.com/forums/ct-...-the-tank.html
jugdish
NX - 1st Gen (2015-2021)
12
03-09-23 07:55 AM
CJS57
ES - 5th Gen (2007-2012)
09-15-10 05:25 AM
biodev
06-08-10 07:22 PM
Mcrusader
03-08-08 11:12 AM
JohnsRX
RX - 1st Gen (1999-2003)
14
10-15-04 08:28 PM
Quick Reply: Gas Tank not empty when gauge says so!
