CT 200h Model (2011-2017)
Ct200h coolant going low
Old Feb 17, 2026 | 03:08 AM
lexus-is2's Avatar
lexus-is2
Default Ct200h coolant going low
My 2013 ct200h the coolant in the bottle dropped very low so I topped it up to the full and after a day driving it around and then checking coolant it seems to have have dropped to minimum.
Unlike a regular 2IS that i am used to where the bottle isn’t pressurised the CT bottle seems like it may be pressurised. How do you pressure test the CT200h? I’ve done the pressure testing on my 2IS where you do it through the coolant radiator pressure cap. But the ct looks a lot different.
is there certain areas I should pay special attention to? I can visually see any pink fluid or wetness anywhere
thank you
Old Feb 17, 2026 | 04:46 AM
morganc's Avatar
morganc
Your head gasket is either starting to leak, or you have a leak in the exhaust-to-coolant-loop heat exchanger. If it were head gasket, you'd normally have rough idle symptoms accompanying this. Either way, prudent to open up the exhaust and to borescope each of your cylinders to check how clean they are/presense of coolant.
2020rc300
RC - 1st Gen (2015-present)
May 8, 2025 07:47 AM
lexus-is2
Apr 6, 2014 05:05 PM
ontoy
Jun 18, 2006 10:06 AM
TMaxxTim
Maintenance
Nov 17, 2004 01:32 AM
azari
Oct 22, 2003 02:33 PM
