CT 200h Model (2011-2017)
2012 ct f sport
Old Nov 19, 2025 | 12:02 PM
Sadlex's Avatar
Sadlex
Default 2012 ct f sport
Hybrid inverter water pump?
mechanic installed new pump and took apart old one after it failed test. Cracked board and corrosion. My car never threw code for anything related to hyb water pump.
Should pump be recirculating upon cold start up?
Is there a fuse location for 12v pump?
Relay?
thanks in advance
Old Nov 21, 2025 | 09:54 AM
morganc's Avatar
morganc
Inverter water pump or engine water pump?
Either way, they will both run when the ignition is on. With an advanced enough code reader, you should be able to read the 'desired speed' and 'actual speed' of each of them.
Old Nov 21, 2025 | 10:49 PM
Sadlex's Avatar
Sadlex
It is a inverter cooling pump. Can not find definitive info on if there is a relay or independent fuse for it and the location of those fuses or relays.
kalvink
RX - 4th Gen (2016-2022)
14
Feb 8, 2024 09:59 AM
pdnejoh
IS F (2008-2014)
Jun 10, 2022 12:13 AM
Lexi66
May 18, 2016 07:28 PM
sorka
Jul 26, 2008 11:47 PM
Overclocker
Sep 24, 2006 06:18 AM
