Choose The Best Suitable Turbo Kits At MaXpeedingRods
Choosing the right turbocharger for your application can be daunting, let alone the entire kit. People may think that choose the kit is easier because all the parts are picked out, but it may not be suitable for your specific application or needs.
The question then becomes "Which kit is best for my application and goals"? In order to solve the trouble of choosing suitable kits, recommend a MaXpeedingRods Universal Turbo and Kits to you They come with everything you need - the turbochargers, wastegate, oil feeds and drains, blow-off valve, intercooler, hardware. https://cimg6.ibsrv.net/gimg/www.aud...060b9e3f6a.png https://cimg3.ibsrv.net/gimg/www.aud...018da436d2.png https://www.maxpeedingrods.com/product/universal-turbo-t3-flange-pipe-bov-adaptor-wastegate-turbocharger-kits-25-psi.html? Application Universal Turbo Kit Perfect For 1.5-3.0L engine This Kit Will add 50-70+HP at 7.5-14.5 PSI. Some features 1.Turbocharger: Capable of Boosting Horse Power up to 500+ HP 2. Intercooler: core size:21*7*2.5 cools down the turbocharged air efficiently 3.Boost controller: Can be set up to adjust boost PSI on the fly, adjusted for any PSI level desired 4. Intercooler piping kit: Made of 6061 aluminum, Lightweight yet strong aluminum piping 5. Turbo Oil return /Feeding line kit: Stainless Steel Braided, Includes complete install kit 6.Blow Off Valve Kit: CNC Billet Aluminum Type RS Style Blow off Valve 7. 38MM Wastegate: Most reliable wastegates For competition vehicles. accurate boost control 8. 5 Blot Turbo Downpipe: CNC machined surface 9. BOV pipe/Adapter: can install anywhere suitable 10.Turbo Boost Gauge: Red LED Illuminated Needles. Comes with All the Wiring Necessary for Installation. The above list is only part of its features, if you want to know more about it, you can click on MaXpeedingRods to slip it. Hope to help you make a choice |
