Sale Blitz power JAPAN Lexus IS200t/IS250/IS350/ISF '14+ coilovers 32 way BLOW out
Blitz ZZ-R Coilover Kit Lexus IS200t/IS250/IS350/ISF 2014+
STRUCTURE:
A single mono tube design is adopted for the complete range. A large 44mm diameter low friction piston control initial damping, allowing a comfortable ride with a sharp driving response.
DRIVABILITY AND COMFORT:
A 32 way damping rate is incorporated into both shock absorbers. With such a wide range of adjustable, driving performance and ride comfort are maintained at the highest level, even at low speed. Spring rate is setup for each vehicle. A comfortable ride can be achieved with the height adjustment function which allows enough stroke for any driving conditions.
STYLING:
The spring sheet and upper mounts are finished in a red alumite. The brackets are finished in a classy matt black. The height adjustment function is shown in millimeters, allowing a wide range of setting to suit any driving conditions.
SETTING:
Preload adjustment of the spring and the height can be adjusted separately. A variety of damping rates can be achieved through simple adjustment. Camber adjustment allows alignment to be set to personal preference.
DURABILITY:
The cylinder case is finished in a black chrome overlay and the bracket is finished in a special point to improve durability and anti-corrosion.
OVERHAUL:
This damper can be overhauled to maintain prime condition.
on sale for $720 PLUS SHIPPING
pm me for questions and shipping qoute
Thank you
Lou
isANDERSON
11-29-15 05:06 PM
PYSpeed.com
Club Lexus Vendor Marketplace
30
07-25-13 04:11 PM
