JDM visor help
Hello CL,
I have some Visors that need to be redone. I thought I did a good job (I was off by a little bit) but a couple weeks back (when it was hot out) the double sided tape loosened and somebody tried taking them off. Theyre a little warped now and the fronts are scratching my body (not as bad as it sounds) Getting to the point, I was wondering if there was someone with the visors in SoCal that wanted to help with the removal and reinstall. I'm thinking I can pick up a nice lunch (as compensation I suppose) and we could work together on it. (the first time I did it by myself, I would like to avoid doing myself and getting someone who knows what they're doing) Posting here and PMs are greatly appreciated. |
Sorry, It's an IS350 BTW.
Should be an easy removal. Just make sure its hot outside so it loosens the adhesive, or you can use a heatgun/hair dryer and remove SLOWLY. They are pretty fragile.
let me know if u need help, i'm from oc, :) you r in good hands :p
