smoked/ tint tail lights.help!!!
nah, i wasnt trying to imply anyone being "stupid" per se, but given the economy, cops are gonna go after what they write up with tickets in order to generate more revenue. i too was ticketed for no front plate, but i was parked on the side of the street. lol. i had my rears tinted at the time, but i guess the cop only saw the no front plate. since then, ive had my front plate on.
Super Moderator
From the other thread. There are other CVC dealing with altering lighting devices so there are several infractions that can be cited if they choose.
Then there is this:
Modification of Vehicle Equipment
26101. No person shall sell or offer for sale for use upon or as part of the equipment of a vehicle, nor shall any person use upon a vehicle, any device that is intended to modify the original design or performance of any lighting equipment, safety glazing material, or other device, unless the modifying device meets the provisions of Section 26104. This section does not apply to a taillamp or stop lamp in use on or prior to December 1, 1935, or to lamps installed on authorized emergency vehicles.
Amended Sec. 26, Ch. 945, Stats. 1997. Effective January 1, 1998.
Required Laboratory Tests
26104. (a) Every manufacturer who sells, offers for sale, or manufactures for use upon a vehicle devices subject to requirements established by the department shall, before the device is offered for sale, have laboratory test data showing compliance with such requirements. Tests may be conducted by the manufacturer.
(b) The department may at any time request from the manufacturer a copy of the test data showing proof of compliance of any device with the requirements established by the department and additional evidence that due care was exercised in maintaining compliance during production. If the manufacturer fails to provide such proof of compliance within 30 days of notice from the department, the department may prohibit the sale of the device in this state until acceptable proof of compliance is received by the department.
Amended Ch. 399, Stats. 1980. Effective July 11, 1980.
24600. During darkness every motor vehicle which is not in combination with any other vehicle and every vehicle at the end of a combination of vehicles shall be equipped with lighted taillamps mounted on the rear as follows:
(a) Every vehicle shall be equipped with one or more taillamps.
(b) Every vehicle, other than a motorcycle, manufactured and first registered on or after January 1, 1958, shall be equipped with not less than two taillamps, except that trailers and semitrailers manufactured after July 23, 1973, which are less than 30 inches wide, may be equipped with one taillamp which shall be mounted at or near the vertical centerline of the vehicles. If a vehicle is equipped with two taillamps, they shall be mounted as specified in subdivision (d).
(c) Every vehicle or vehicle at the end of a combination of vehicles, subject to subdivision (a) of Section 22406 shall be equipped with not less than two taillamps.
(d) When two taillamps are required, at least one shall be mounted at the left and one at the right side respectively at the same level.
(e) Taillamps shall be red in color and shall be plainly visible from all distances within 500 feet to the rear except that taillamps on vehicles manufactured after January 1, 1969, shall be plainly visible from all distances within 1,000 feet to the rear.
(f) Taillamps on vehicles manufactured on or after January 1, 1969, shall be mounted not lower than 15 inches nor higher than 72 inches, except that a tow truck, in addition to being equipped with the required taillamps, may also be equipped with two taillamps which may be mounted not lower than 15 inches nor higher than the maximum allowable vehicle height and as far forward as the rearmost portion of the driver's seat in the rearmost position. The additional taillamps on a tow truck shall be lighted whenever the headlamps are lighted.
Amended Ch. 924, Stats. 1988. Effective January 1, 1989.
