Need central windows and locks fixed (2002 GS300)
Need window and central door locks fixed (2002 GS300)-FIXED
Good Morning,
My wife's 2002 GS300 has some electrical issues.
The driver's window refuses to go up and down all the time.
The central locking system is not working (only a few doors lock).
I would like to take it to someone to have it fixed.
Any suggestions?
We are located in the Culver City/Santa Monica area.
Feel free to text me at 215-554-1999.
Thank you,
Tano
Any suggestions?
Thank you,
Tano
On my 1998 my window switch on the drivers side is going out.. Worst case scenario I'll just use the key on the outside door lock to roll it up. As for the door locks not working. If you mean the power locks dont work there is a few DIY's in the GS section. For $35 and a few hours you can replace them all..
Good Morning,
The window goes down no problem but has problems going up...you have to play with the button over and over and it can take 10 seconds or sometimes minutes before it magically decides to work and go up.
It's as if the motor is dying?
I will contact Tommy.
Thanks guys!
Thanks guys!
Lex,
The key method works for all except the faulty window. So it's probably the window switch.
I just ordered the Mabuchi motors for the door locks.
I will look into the window switch. This is the car my wife drives so need to fix this stuff ASAP.
Thank you,
Thank you,
I had issue with my driver's window not rolling up. One day the stars aligned and the window rolled up within a few clicks. Then a buddy of mine rolled it down, and since, never went back up.
Turned out to be the window's Multiplex Computer. I swapped it out with the passenger sides to roll it back up.
Finally got one from the classifieds. All is good now.
Hello,
HUGE and I mean HUGE thank you to lexo98.
I drove up to his house on Saturday and we swapped the multiplex on my driver window (he had one) which fixed the issue.
We also replaced the door lock actuator motors on the driver rear and passenger front doors.
All windows and door locks work perfectly.
He did not remove the windows or door handles to get this done.
Thank you sooo much Sir, you have no idea how happy I am that this is fixed!!!!!
Take care,
T
Take care,
T
Hello,
Take care,
T
Take care,
T
gizmatix
07-16-12 10:52 AM
