View Poll Results: When is the last time you had a catastrophic tire failure that REQUIRED a spare tire?
Within the last year
14
24.14%
1-5 years ago
16
27.59%
6-10 years ago
8.62%
11-20 years ago
12.07%
20+ years ago
8.62%
Never, but I've been driving less than 10 years
5.17%
Never, and I've been driving over 20 years
13.79%
Voters: 58. You may not vote on this poll
When's the last time you had to use a spare tire (I.e had a catastrophic flat tire)?
#61
Thanks for sharing. Would of been a whole different experience if there was full size spare .
#63
Agreed....I'm presenting it from the point of view of car-people like us, who know how new vehicles are sourced, and where they come from. The average John Q. Public, most of the time, doesn't. But my point is that if Opel doesn't design the trunk (or the cargo-area of the wagon, which is also sold here) with enough space for a full-sized spare, one cannot blame Buick...they aren't going to completely redesign the trunk just for the American market.
#65
So I did a bit of research. The Opel comes with either a flat kit or a spare. The Buick is just a flat kit. My opinion, this is all on Buick
#66
I'm not disagreeing with you.....again, I was talking about a "what if?" scenario that was brought up. I think you and both have made it clear that we agree that having a spare is important. A real full-time spare, of course, is best, but few vehicles outside of off-road-capable trucks and SUVs offer them today. So, in that case, a full-size temporary spare (like I had on my Verano when I needed it) is the next-best alternative.
#67
Had three flats on my Good Years in 5 years. Went through 3 new tires.
The issue with tires and a spade saver is that if it goes on a long trip, you are really out of luck. How far can one go on a space saver? All cars should have at least a full size spare, that way a long journey can continue, at full speed and full distance.
Once I was on a road trip with my Mom & the right rear tire failed. I knew it was unrepairable so mounted the spacesaver. driving 55 mph for about 200 miles to get to a large town to replace the tire was no problem.
What kills any tire is overheating it. Easiest way to do this is excessive weight or not enough air pressure to support the load. As long as you drive appropretely with the spacesaver there is no limitation on distance. I think most start with 5/32nds tread depth for cars.
#68
It's even worse on AWD vehicles, with a center-differential. In some cases, the AWD must be disconnected by pulling a fuse or turning a switch off, leaving the vehicle in FWD, and the smaller tire put on back. If it's a front tire that fails, one of the good ones from the back is switched up front so that you have two regular tires up front, and the smaller one put in back. The idea is to not have a smaller tire than the other three up front, where the difference in wheel-rotation can mess up the differentials/final-drive units from too much heat-buildup. At the time I owned my Subaru Outback, for example (10-15 years ago), that was SOP for many AWD vehicles on a tire-failure...though, since then, advances in the AWD systems themselves may have lessened the need for that procedure.
#69
Only time I've had to utilize a spare was when I ran over some construction debris that flew out of a dumptruck. Luckily it was my pickup, so fullsize spare, and it was just one nail, so I had time to get off the highway and into a parking lot.
#70
Some places, of course, have covered-load laws for dump-trucks, but that doesn't always stop all of the debris from getting out.
#71
The auto manufacturers, though, seem to disagree. Temporary, donut, and run-flat tires usually have clear warnings and disclaimers on them limiting them to around 50 miles or so, at 50 MPH or less. They are simply not meant to replace a true spare tire, which is the same as the four OEM's and can even be rotated with them.
#72
drives cars
I do notice the following warning in the owner's manual, as well:
Also, not only can the following system not be utilized fully, but it may even negatively affect the drive-train components:
• AWD system
• AWD system
#73
Dysfunctional Veteran
I am pretty peeved that my full-size, 60k+ MSRP, 4x4 Pickup truck has a donut under the back end.
IMO, any car other than compacts should come with a real spare. My ES has one, and I actually had to use it about 2 months ago. I was on my way to Commerce TX, from my home. Thats a roughly 50 mile one-way drive. Had I had a donut spare, I would have had to drive about 85 miles on it.
#74
I was out of town and just came back to this thread. I find it really surprising that 52% of respondents have in fact had a CATASTROPHIC flat in the past 5 years...
#75
drives cars
Ha ha, yeah perhaps that's not the best word choice. I think a flat is a flat. If you have one, you're not going anywhere fast.
