What's inside a Catalytic Converter?
8 Attachment(s)
I chopped open the catalytic converter on my Corolla to see whats inside and how it works. Here's a video:
The catalytic converter is located between the manifold and resonator in the exhaust system. Its purpose is to convert toxic gasses from the exhaust stream into less harmful gases. Attachment 491618 There's an oxygen sensor behind it for the ECU to monitor catalytic converter performance. Attachment 491619 Attachment 491620 Grinding it open: Attachment 491621 Attachment 491622 Inside there is a honey comb shaped ceramic membrane coated with precious metals. That's what makes them so expensive. Attachment 491623 The precious metals act as a catalyst, encouraging a reaction to occur from toxic gasses to less harmful gasses in two stages, reduction and oxidation. Attachment 491624 The ECU controls the air to fuel ratio with the first sensor before the catalytic converter. It must be 14:1 for optimal combustion and catalytic converter performance. The rear oxygen sensor ensures enough oxygen exits the converter and that it is working properly. Otherwise you'll get a P0420 or P0421. Attachment 491625 |
Originally Posted by speedkar9
(Post 9875344)
What's going on when there are 4 of them on a car.....(my 335i has 4)...that seems like expense and weight....
edit here's a pic, there are two more cats after the turbos....not shown http://f30.bimmerpost.com/forums/att...1&d=1339722283 |
Originally Posted by Johnhav430
(Post 9875596)
I've never had a CAT fail on me on any car, to include the Maxima being 19 y.o. (it has EGR issues, but not CAT, which is original). I've always felt like that's something you don't want to replace due to cost, and the questionable quality on replacements vs OE.....
Also I'm quite fascinated by the fake dual exhaust phenomenon..when did it start, late 80's? Who started it? I know in the earlier days, they were real, with straight pipes right out of the manifolds of a V8. Imagine that today, you can have dual exhaust on an inline 4? Which of course has nothing more than a y-pipe...also curious if an engineer had free rein, what would they design in this day and age, say out of a V8? |
(Post 9875355)
Those precious metals are usually derived from platinum, palladium, or rhodium. Platinum sometimes costs more than pure gold.
(Post 9876505)
Yep agreed. I too was surprised that gold can be used in the cats, no wonder they're so expensive and used ones are in demand.
(Post 9876505)
| All times are GMT -7. The time now is 07:48 PM. |
