Deep Dive: Lincoln MKC Concept
Old 01-12-13, 10:41 PM
Hoovey689
Hoovey689's Avatar
Default Deep Dive: Lincoln MKC Concept
Lincoln MKC Concept shows real promise
Gallery:
http://www.autoblog.com/photos/linco...photo-5564360/
Ford's efforts to resuscitate its moribund Lincoln luxury brand began in earnest with the introduction of its 2014 MKZ sedan, a model many labeled as the marque's make-or-break offering. Of course, one model does not a comeback make, and with the MKZ just now starting to trickle into dealers, it will be some time before America's jury of consumers comes in with their judgment. More to the point, it's likely to take better than a decade's worth of products and sustained marketing effort to even begin to figure out whether Lincoln has a shot at redemption or if it will die of Mercury poisoning. After all, rival General Motors has been pouring resources into Cadillac since the late '90s, and if the sales charts are any guidance, it's still probably too early to declare its rebirth a success.
Certainly, a brand with Ford's resources, free of distractions (read: the now-defunct Premier Auto Group and various other side projects) should be able to successfully market a single luxury brand, particularly one with such a rich – if distant – history. Especially now with the Blue Oval enjoying more consumer goodwill than at any time in recent history. So let's all give Alan Mulally and friends a little room to work, eh?
We can start by focusing on the compact crossover seen before you, the Lincoln MKC Concept. Riding atop the same global C-platform that underpins the Ford C-Max, Escape and Focus, the MKC showcar here presages a production small CUV that will stick its distinctive nose into one of the auto industry's fastest-growing segments.
Lincoln's future hinges on first impressions as much as anything else, and to that end, the MKC Concept makes a darn good one. We've had the chance to spend some up-close time with this vehicle ahead of its Detroit Auto Show debut, and it's a surprisingly handsome machine. We say "surprisingly" because, by general consensus, the Autoblog staff has been less than complementary about the brand's new design language – mainly its split-wing grille said to hark back to the 1938 Lincoln Zephyr. The MKZ sedan was the first clean-sheet Lincoln we've seen that incorporates this feature, and while distinctive, our team remains split on its aesthetic success largely because of its.
That's why we're so glad to see the MKC – to our eyes, the two-piece split-wing setup works beautifully here. It's at once distinctive and harmonious, with two distinct textures lending it more nuance and richness than its sedan counterpart. The grille's added height (or that of the headlights that buttress it on either side) may also deserve some credit here, as might the deep-draw creases on the hood, which give the design directional thrust, drawing the eye from the base of the windshield across the bonnet, through the grille and down into the lower fascia.
The side view is no less attractive, with deep-draw sheetmetal and an aggressively raked backlight. Aside from an interesting matte-chrome cutout along the rocker panels to cut visual bulk, the profile's most interesting feature is the cutline created by the wraparound liftgate. The rear is likewise positively impacted by the hatch design, which features a beautifully uninterrupted full-width taillight treatment that's almost Porsche Panamera Sport Turismo in execution, along with nicely detailed exhaust outlets and lower fascia.
Dimensionally, the MKC Concept isn't far off of the Escape, thought there are some important variances. At 106.9 inches long, this Lincoln rides atop a slightly longer wheelbase than the Ford (105.9), and at 179.3 inches overall, it spans 1.2 inches longer, too. In typical showcar tradition, it's also a fair bit wider (76.1 inches sans mirrors), where the Escape is 72.4 inches wide. Likewise typical of the exaggerated aggressiveness in the concept car genre, the MKC is 63.2 inches tall, a full 3.4 inches shorter than the Escape. Some of that is likely from a chopped-down greenhouse, but it might ride lower as well (no ground clearance figures have been released).
So we're probably not looking at the exact Lincoln MKC production model, even if you factor in realistically sized side mirrors and add door handles and such. However, this is far from pie-in-the-sky territory; there are realistically sized wheels marking out the corners (stout 20-inch seven-spoke pieces), though we assume they'll need to decrease the windshield rake a skosh and put frames on the windows. The big question is whether engineers will be able to keep the clamshell liftgate, a feature other models using the C-platform don't have.
The interior is flat-out gorgeous, with a clean and modern aesthetic that doesn't resort to a lot of showcar trickery like center-mounted floating seats and improbably shaped instrument panels in order to wow. It also avoids the trap of being too austere – there's a warmth to this design.
With the exception of the full-length center console that makes this a four-seat vehicle, we think the production MKC's interior could survive largely intact, even the panoramic roof (sans center rails). Strip away the leather covering every surface and you're still left with a lot of interesting details that could see production, including air vents that mimic the vanes on the split-wing grille up front and subtle Lincoln Star-pattern detailing repeated everywhere from the stitching to the speaker grates. Even the seats are built on production frames borrowed from the MKZ. We particularly like the artful control stalks (they remind us of a saxophone's neck and mouthpiece), though we don't expect them to make production. The unusual reconstructed real wood trim, which is comprised of layers of compressed endgrain finished with a bit of metal flake to draw out the ridges, however, just might. Rich, labor-of-love details like this could make all the difference to potential buyers looking for a reason to splurge on a Lincoln over entrenched premium brands like BMW or Mercedes-Benz. Other showcar-like details including the pushbutton shifter and minimalist center stack with capacitive-touch switchgear is already a production reality on the MKZ, too.
Lincoln remains mum on what powers this showcar (if indeed it even has one at all), but the production model will likely arrive under four-cylinder EcoBoost motivation, skipping the Escape's base 2.5-liter Duratec engine altogether. It is here that we hope Ford will splash out a bit – upscale design and nicer accommodations are great, but we feel strongly that luxury customers want greater power and technology underhood than what is found in their more common Blue Oval-badged counterparts. Thus far, Dearborn has yet to demonstrate that it feels the same way.
Make no mistake. Lincoln has a long, tough climb back to relevance ahead of it. Not only does it need to continue to radically renovate its product range, it must boldly recast its public image and fundamentally reinvent its dealer experience from brick and mortar to customer relations. The MKC concept isn't radically innovative in any particular area, but it does suggest that Lincoln's design language has legs. It also helps that the production model is poised to move into one of the industry's fastest growing segments, one that lacks a truly dominant player. As places to reinvent a brand go, the small premium crossover segment ain't a bad place to start.
http://www.autoblog.com/2013/01/13/l...-real-promise/
Hoovey689 is offline
Old 01-12-13, 10:47 PM
Hoovey689
Hoovey689's Avatar
Lincoln needs this period.
I'm a huge Blue Oval fan as many know, so I'm a big supporter of Lincoln's revitalization. Building something people want to drive is always a good start. Especially when it is luxurious and chic.
Personally I think this would make a great competitor to the X3, upcoming NX, GLK, Q5, RDX.
Old 01-13-13, 08:27 AM
MPLexus301
MPLexus301's Avatar
Very sharp looking. I hope Lincoln builds this and keeps it as close to the concept as possible.
MPLexus301 is offline
Old 01-13-13, 09:13 AM
grabber2
grabber2's Avatar
The ext. looks great.....but don't like the inside......
grabber2 is offline
Old 01-13-13, 11:00 AM
pbm317
pbm317's Avatar
Great blend of Evoque and Q5 (clamshell tailgate) in the exterior design.
pbm317 is offline
Old 01-13-13, 09:21 PM
jwong77
jwong77's Avatar
Very sharp. That is the best interpretation of the waterfall grille thus far.
jwong77 is offline
Old 01-13-13, 10:04 PM
Fizzboy7
Fizzboy7's Avatar
Excellent looking truck. Exterior is slick and clean, but interior falls short. Center stack is carrying too much blubber around the sides and there's too much top-surface showing.
Fizzboy7 is offline
Old 01-13-13, 10:39 PM
Received 2,126 Likes on 1,378 Posts
greeeeaaat looking! bring it lincoln!!!!!
bitkahuna is offline
Old 01-14-13, 09:15 AM
GS3Tek
GS3Tek's Avatar
Doesn't look too bad
I'd say it would look much better if they just cut back on the horizontal slats from the grill.
GS3Tek is offline
Old 01-14-13, 09:20 AM
mmarshall's Avatar
Yes, I agree that, at least from the pictures, this is an improvement on the MKX....but I don't see it as Lincoln's most crucial need right now. What they should be doing with their development-money, right now, IMO, is to toss the MKS and design a real flagship.
mmarshall is offline
Old 01-14-13, 10:41 AM
Hoovey689
Hoovey689's Avatar
Yes, I agree that, at least from the pictures, this is an improvement on the MKZ....but I don't see it as Lincoln's most crucial need right now. What they should be doing with their development-money, right now, IMO, is to toss the MKS and design a real flagship.
Actually I disagree. A MKS flagship is not a high volume seller like the MKC would be. The success of the MKC would drive the production of a flagship, so it essential that a small Ute and small sedan make the company profitable first before venturing back into flagships, coupes, verts etc..
Old 01-14-13, 02:29 PM
mmarshall's Avatar
Your opinion respected...but have you driven an MKS? IMO, for a number of reasons, it's not a very impressive flagship, though it admittedly does have the AWD bad-weather option that the Town Car lacked for years.
I agreed, BTW, that the MKC, at least on paper and in the photos, seems a step up from the also-unimpressive MKX.
Old 01-14-13, 02:35 PM
speedflex
speedflex's Avatar
Put some door handles and real mirrors on it and it's ready for the showroom!
speedflex is offline
Old 01-14-13, 05:19 PM
Hoovey689
Hoovey689's Avatar
I have not, but like the RL/RLX/M37/56 it never really was a true flagship to begin with. So missing out on a real one for a few more years isn't so bad if they can become more profitable and make people actually consider Lincoln's viable options to the competition.
Despite being smaller, it is more impressive than the MKX. Luckily if the new MKZ and MKC are signs of things to come, the next midsize CUV should be bounds better too
Old 01-15-13, 10:21 PM
LexLaw
LexLaw's Avatar
I'm definitely feeling this Evoque/Q5/RDX fighter. Lincoln appears to be bringing it as of late. As mentioned earlier by JWong, this is by far the best interpretation of the new waterfall grille. Great job by Ford as they are finally looking to bring the Lincoln brand back in proper form. Having its own design studio is a major step.
LexLaw is offline
Quick Reply: Deep Dive: Lincoln MKC Concept
