HELP. New Car won't start after 3+ month left out in the Winter.
Old 08-26-11, 08:28 PM
turtle11
turtle11's Avatar
Default HELP. New Car won't start after 3+ month left out in the Winter.
I left out my new car 3+ month outside doing Winter without garage and when i finally try to start it, it won't start now.
Should i take it in the shop? Hope this is not a lemon, cause it's a brand new car!
turtle11 is offline
Old 08-26-11, 08:53 PM
Hoovey689
Hoovey689's Avatar
The battery is probably dead...
Hoovey689 is offline
Old 08-26-11, 08:54 PM
Justin2JZ
Justin2JZ's Avatar
Is it turning over or is it just clicking?
Justin2JZ is offline
Old 08-26-11, 08:59 PM
tofu_house
tofu_house's Avatar
Did you turn the car on and let it run for like 10-15 minutes every couple of days? If you just left it off for the entire duration of those 3 months, the battery is probably dead.
Did you try jumping it?
tofu_house is offline
Old 08-26-11, 09:09 PM
turtle11
turtle11's Avatar
Clicking i believe.
turtle11 is offline
Old 08-26-11, 09:13 PM
Justin2JZ
Justin2JZ's Avatar
Yep, definitely dead battery then. A jump start should start er' right up.
Old 08-26-11, 09:24 PM
turtle11
turtle11's Avatar
No, couldn't get it to turn on doing the cold, so i just let it sit though the winter until the whether warms up a little. Winter have pass now and it's running fine now. Im just curious why it won't turn on doing that time. Could it be frozen or a lemon?
turtle11 is offline
Old 08-26-11, 09:28 PM
turtle11
turtle11's Avatar
Never jump start it. It's starting again after the whether warm up.
turtle11 is offline
Old 08-26-11, 09:29 PM
Hoovey689
Hoovey689's Avatar
Because if you leave any device with a charge, it will diminish after time. You need to turn it on every now and then and let the alternator charge the battery up
Old 08-26-11, 10:15 PM
turtle11
turtle11's Avatar
What about all the new cars sitting at the dealer lot for months or even years, they don't diminish and doesn't need to jump start every time someone buys one.
turtle11 is offline
Old 08-26-11, 10:30 PM
Hoovey689
Hoovey689's Avatar
I assure you they are started, moved, test driven, washed, serviced and so forth. I work at a dealership
Old 08-27-11, 08:12 AM
<VENOM>
<VENOM>'s Avatar
thats hilarious I can agree with the 1st 2, the rest, not from what I have seen, pdi not serviced
<VENOM> is offline
Old 08-27-11, 09:56 AM
spwolf
spwolf's Avatar
car is not a lemon if your battery died.... dealers constantly have to maintain the battery on cars in the showroom or lots...
spwolf is offline
Old 08-27-11, 01:20 PM
-J-P-L-
-J-P-L-'s Avatar
I worked at a dealer for 3 years and had to jump start NEW cars 100's of times, mostly in the winter of course. Fact is, new cars often sit for months without being moved much. Sometimes, they're just started and moved for a minute which isn't enough to recharge. Most dealers use demos for test driving so that you're not putting miles on all the cars.
-J-P-L- is offline
Old 08-27-11, 07:43 PM
T0ked
T0ked's Avatar
Don't do this. Old myth. This actually does more harm than good. Unless you turn it on and drive it around for half an hour or so. All this does is build condensation in the engine and exhaust systems. And it doesn't warm the engine enough to burn off the condensate. Great way to eventually mess up your engine. There is no danger in just leaving it off (unless it is longer than a few months). Make sure you put in fresh gas, maybe some fuel stabilizer, fresh oil, and either remove battery or just remember to recharge it.
To the OP, yeah, sounds like the battery. If it is completely discharged, get a battery charger and charge it over night or so. Jumping it will get it started but car may run unpredictably. Might shut off if you take it for a drive.
T0ked is offline
Quick Reply: HELP. New Car won't start after 3+ month left out in the Winter.
