man my 240sx motor blew
I am so soo bummed out right now.
http://www.az240sx.org/forums/index....0&#entry346952
I wanted to do a sohc Ka build up. Have a strong sohc ka, then turboing it later.
I have a spare block sohc ka I could use.
But im paranoid now. If i build ka I want it to have forged internals carefully put together with patience... I never, ever, ever want to deal with a blown motor ever again. Im getting flares and warning stuff.
Or maybe I should swap an Sr20det and call it a day... but what if it happens again.. you never know what you get with those jdm motors....
you can stick with another ka if you want, but there are better (relatively speaking) parts for the SR20 than the KA24. What was done to the engine/car before it blew up? I will go on a hunch, without hearing the details, and say that it might have been running lean or bad water/cooling problem.
Either motor you decide to build, make sure you get a quality water temperature (very important), oil temp/pressure, and boost (if applicable) gauge when touching either of those nissans. good luck.
M.
Originally Posted by videcormeum
A SR20DET swap is going to cost quite a bit - over $10,000 most likely.
M.
M.
M.
M.
3,900 installed.
10,000? .... not even a S15 6 speed should cost that much dude...
IF im doing this and keeping it at its 200 hp level for some time. And build the rest of the suspension/ wheel/tire, bigger brakes etc etc.
I have a spare ka in unknown condtion im trying to get a local person to come with a leakdown tester and check it for me.
It was a stock sohc, just a cone filter in place of the stock air box. I took the valve cover off, and spark plug wires off and cranked the motor. It knocks each time the intake valves in cylinder 3 opens.
Im guessing a spun bearing?
Im really undecided.
If I really choose this route, i could slap some better tires, and call the swapped 240sx done for quite some time while I concetrate my efforts on the SC300.
Anti-Venom
Jun 25, 2011 11:35 AM
lexdiamon
GS - 1st Gen (1993-1997)
Aug 23, 2006 10:54 AM
