help setting garage door opener
Old Jul 31, 2004 | 04:09 PM
athena's Avatar
athena
Unhappy help setting garage door opener
Can anyone tell me how to get the garage door opener programmed to the manufacturer one in the visor? I've tried several times and can't seem to get it to work...no dumb blonde jokes please...I really have tried, it just doesn't want to work. Step by step would be great. Thanks!
Old Jul 31, 2004 | 05:05 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
Default Re: help setting garage door opener
its step by step in the manual but ill look for you just in case
Old Jul 31, 2004 | 05:28 PM
lexusondubs
dubsonlexus
do you have a gs if so wut year ??
Old Jul 31, 2004 | 05:36 PM
lexusondubs
dubsonlexus
1. push and hold down the button for 20 seconds until the light begins to flash
2.bring the garage door opener 1 inch from the button being programmed then push the button on the garage door opener
3. when the frequency is registered the indicator flashes rapidly then you can release both buttons
thats it i hope i helped .....................shawn
Old Aug 1, 2004 | 02:08 AM
nthach's Avatar
nthach
it depends on the brand, if you have a Chamberlain/Lift-Master or Craftsman, there should be instructions on the opener. Genie is a slighly different procedure, are you trying to program an HomeLink remote?
Old Aug 2, 2004 | 11:30 AM
GS3Tek's Avatar
GS3Tek
Some of the brands mentioned have rolling code, so you can't do it the conventional Lexus way. I am also trying to program my garage again, so I will post again when I figure it out, unless someone can chime in earlier. Sorry, not much help yet. If the gdo is on the visor, then it's probably an RX???
Old Aug 2, 2004 | 12:14 PM
nthach's Avatar
nthach
one way to find if your garage door opener uses rolling code is look at the remote, if it says Intellicode or Security +, and you open up the battery door and there are no DIP switches, then it's rolling code.
here's some help from Lift-Master that will work on all Chamberlain openers(Chamberlain/Lift-Master/Craftsman):
http://www.liftmaster.com/cw/faq/residential/#11
and from Genie:
http://www.geniecompany.com/Support/replaceremote.htm
Bliz460
Nov 23, 2016 05:02 PM
sleeperGS
Feb 13, 2010 10:59 PM
Lettuce
Nov 14, 2003 12:43 PM
RefinedGS
Oct 10, 2003 01:43 PM
enginyr
Nov 21, 2001 10:55 AM
