Canada For events in Canada.
Mechanic in GTA
Old Dec 19, 2007 | 08:53 AM
LexSaZ's Avatar
LexSaZ
Default Mechanic in GTA
Hello everyone,
I started this topic a while ago and thanx a lot for all of your input skperformance ....as mentioned in my previous thread in my 2000 GS400 the VSC?ABS/VSC OFF lights in the dash came on and then went away after a while but monday evening the lights came back on again and they are still on so i took the car to a mechanic...I went to Besil TLEX...he got the code of the computer and as per the code the Front Right Side Brake Sensor FAILED/Not Working...I went for a test drive with him and he had the computer thing installed on the car while driving all the brake sensors were giving the readings except for the Front Right Side Brake Sensor...but when he took out the sensor and did the reading the sensor reading were fine mechanic told me that the SPECS of the reading are fine and now he is not sure what is keeping the lights on he even tried to decode them or reset and make them go away or wtever you call it but it wasnt working.....mechanic told me he needs more time for DIAGNOSIS.....Any idea anyone? Any input please that will help....
ANYONE KNOW ANY GOOD MECHANIC IN GTA...ANY IDEA WHERE SHOULD I TAKE THE CAR.....PLEASE ADVISE/HELP
Please & Thanx......
Old Dec 19, 2007 | 05:57 PM
skperformance's Avatar
skperformance
If he checked the sensor ,did he check the harness it plugs into for power?
I would lean towards the wire being damaged.
Old Dec 20, 2007 | 04:11 PM
BDSL's Avatar
BDSL
Few possibilities:
1. The element inside the sensor might be shorting or damaged...resulting in intermittent readings.
2. Damaged or shorting of the harness or electrical connector.
V8Life
Nov 12, 2024 06:11 PM
LexSaZ
Nov 7, 2023 10:20 AM
Aznteazer
Feb 10, 2022 11:36 PM
andym666
Jul 29, 2017 11:16 AM
UpstateLex
Mar 23, 2011 06:01 PM
