Creegan’s Green Goblin - 1100whp or bust
Hey guys ,
Finally bit the bullet and ordered more then half my parts. Still waiting on some stuff to come in and I will begin the deep dive in a few weeks. build overview 1999 sc300 324k motor will be running a stock 97 ge head and block golebys cam trigger kit 272 bc cams Bc single hd springs and to retainers arp basic headstuds -undecided on hg phr billet timing belt tensioner titan v 2 crank pulley ebay ffim welded to the 96 lowers - this lower doesn’t have air assist silky thermal gasket trans and drivetrain tremec f mag - grannas setup tilton 246 hd twin disk tilton hydro bearing 8.8 grannas kit with pro axles and hubs eaton lsd ford performance 4.10 final drive and pinion solid mounts 07 explorer diff turbo setup spa turbo manifold sxe 369 with 1.0 ar t4 exhaust housing klm 1000hp intercooler turbosmart 45 gen v gate turbo smart race port Bov blitz nur spec exhaust custom intercooler piping custom 4.5- 4 - 3 inch exhaust - will look like a 2 stroke fatty pipe Fuel pump e85 phr triple pump hanger phr triple pump wiring- heavy duty and truely BA 2- 525 hell cat pumps 8 feed 6 return radium fuel rail fid 1600’s Electronics haltech 2500 elite haltech ic7 dash ethonal sensor boost solenoid suspension stance mvp signature drag coilover setup I’m going to start with a basic photo dump, fixed a few things wrong with the car when I bought it. Cleaned the interior, pulled the trashed seats, cleaned carpets, fixed the clogged sunroof drains, fixed the cracked sunroof tubing, pulled entire interior minus dash to steam and disinfect and clean. Steamed headlined and stain removed a few spots , rehoused and swapped a few broken clips and trim pieces. Buffed headlights and power washed entire car and engine bay. Here are just a few to begin with https://cimg0.ibsrv.net/gimg/www.clu...0e56c3049.jpeg Purchase day https://cimg8.ibsrv.net/gimg/www.clu...d7ed0537f.jpeg Purchase day 2 https://cimg5.ibsrv.net/gimg/www.clu...7e72d5342.jpeg Another side shot the day I picked her up https://cimg8.ibsrv.net/gimg/www.clu...43cea4463.jpeg Time to remove some dumb stickers https://cimg0.ibsrv.net/gimg/www.clu...16f7bf07a.jpeg Pretty clean for 320k plus https://cimg3.ibsrv.net/gimg/www.clu...f0cdf2e43.jpeg Door dings https://cimg5.ibsrv.net/gimg/www.clu...1bbd73e2e.jpeg Pretty straight body, not the best paint https://cimg0.ibsrv.net/gimg/www.clu...5d0bcac1c.jpeg Small ding https://cimg3.ibsrv.net/gimg/www.clu...f6b766b1d.jpeg https://cimg4.ibsrv.net/gimg/www.clu...42c160c68.jpeg Clear coat failure. This car was repainted at some point https://cimg5.ibsrv.net/gimg/www.clu...2b445c194.jpeg Some paint issues https://cimg7.ibsrv.net/gimg/www.clu...ac4440b28.jpeg https://cimg8.ibsrv.net/gimg/www.clu...df613945a.jpeg Had all the dealer key tags but no remote key. Will need to get the remotes programmed and setup in the next few weeks. https://cimg0.ibsrv.net/gimg/www.clu...4ca575c46.jpeg Nice find in the trunk. Car needs lower control arm bushing but will Probly just put figgs arms in there So the seller said the car had 200k plus…. https://cimg2.ibsrv.net/gimg/www.clu...b36b472d2.jpeg Broken odometer, little research and found a quick fix https://cimg3.ibsrv.net/gimg/www.clu...7de669aae.jpeg And yeah it had more then 200k on it , 320k lmao |
just a few more for y’all!!
8.8 ready to get a Lsd and 4.10 gears https://cimg4.ibsrv.net/gimg/www.clu...6ddae4ad5.jpeg https://cimg6.ibsrv.net/gimg/www.clu...2a14476f2.jpeg Pro level axles with billet hubs from grannas https://cimg5.ibsrv.net/gimg/www.clu...0a2b8cc5e.jpeg Pain in the butt to pull https://cimg9.ibsrv.net/gimg/www.clu...622f87aba.jpeg Need to refinish these from the sc300 https://cimg2.ibsrv.net/gimg/www.clu...9f759148a.jpeg She’s been sitting on the stand for over a year. 2022 is your year https://cimg3.ibsrv.net/gimg/www.clu...3ba07b658.jpeg Longest wait https://cimg4.ibsrv.net/gimg/www.clu...1bf91f1a6.jpeg Japan ftw https://cimg5.ibsrv.net/gimg/www.clu...bd3afe551.jpeg 90mm https://cimg6.ibsrv.net/gimg/www.clu...5d1d30be4.jpeg Turbosmart 45 gen v https://cimg7.ibsrv.net/gimg/www.clu...9357f5b86.jpeg Cleaned headlights |
This is looking like it’s going to be a really nice build.
Looking forward to this one! A quick polish would remove quite a bit of that oxidation and make the car look a heck of a lot better.
Originally Posted by ThomasGS4
(Post 11217898)
actually the car was resprayed at some point in its life. I plan on getting it built and tuned first then the next step will be pulling the windshield and getting a nice paint job. Going to keep the factory color , might add in a more gold flake to the green. Color scheme is going to be bronze and green. This is my 3rd of 4th sc build, so I’m going all out on the car. Minus a built motor lol 😂 |
Originally Posted by Kira X
(Post 11217421)
should be a fun one for sure, let’s see if I can get the front wheels up lol 😂 |
8.8 diff
Dustin received all the diff parts finally this weekend:
4.10 ford performance gear set motive bearings and rebuild kit tru trac Lsd and he got the case cleaned up and looking like new !! https://cimg7.ibsrv.net/gimg/www.clu...bc9d4ae9c.jpeg Looks 10x better then when I sent it to dustin https://cimg8.ibsrv.net/gimg/www.clu...c79f5d1c8.jpeg Looks like new Dustin will also be knocking out the old bushings as I have solid aluminum ones on the way. |
any writeup anywhere on that goleby’s trigger kit ..how to wire and and how it works ? Am curious 🤔 …good luck on the project !
@gerrb i opted for the cherry trigger sensor. It’s a really nice kit from the looks of it. Here is the wiring diagrams and a picture of the kit.
https://cimg7.ibsrv.net/gimg/www.clu...027a03f61d.png https://cimg1.ibsrv.net/gimg/www.clu...89b0cfac84.png https://cimg5.ibsrv.net/gimg/www.clu...d7140a3f36.png https://cimg6.ibsrv.net/gimg/www.clu...67acf4cb3e.png |
@Rcreegan thanks buddy ... am curious since I have a couple of low mileage good 97 and below engines around and wanted to experiment with them :D .
Originally Posted by gerrb
(Post 11223996)
only bad thing is I don’t think the stock fan will clear with the cherry sensor , but once I get there I’ll be posting pictures and all that stuff. |
Originally Posted by Rcreegan
(Post 11224477)
Originally Posted by mrmj2u
(Post 11224832)
Hello! How did you get your Golebys kit? Did you buy it directly from Golebys?
yeah I just shot them a email . It only took a week during the beginning of Covid. |
(Post 11225179)
(Post 11225513)
Ok Awesome! Emailing them now. This looks great.
yes , it’s a pretty high quality kit. Just remember it’s in aud which is like half the price in usd |
| All times are GMT -7. The time now is 06:50 AM. |
