Build Threads Details on Club Lexus IS-F owner vehicles
JT2MA71's 2014 UW build
Old Mar 22, 2025 | 08:14 PM
  #631
JT2MA71's Avatar
JT2MA71
Old Mar 29, 2025 | 11:20 AM
  #632
Defratos's Avatar
Defratos
Btw did you have to roll your fenders to fit those wheels?
I'm sure you've probably mentioned it somewhere in your thread
Old Mar 30, 2025 | 02:50 AM
  #633
JT2MA71's Avatar
JT2MA71
Rear fenders are only half rolled (some lip left) but front fenders are untouched, just flattened plastic fender liner protrusion.
rear fender.
rear fender.
Old Mar 31, 2025 | 09:24 AM
  #634
Defratos's Avatar
Defratos
rear fender.
Thanks, but did you need to do any fender work for the below wheel setup? seems to have enough of a gap for the wheels to fit, but not sure if this would have needed fender work as well?
Old Mar 31, 2025 | 11:42 AM
  #635
JT2MA71's Avatar
JT2MA71
No, picture shows current fender. no added fender work with the bronze wheel setup. bronze wheels are only 0.3 mm more aggressive than the apex wheels as far as poke.
Old Apr 1, 2025 | 01:38 AM
  #636
Defratos's Avatar
Defratos
Ok, so I understand that someone would still have to do some fender work to fit this bronze wheel setup? or no because they aren't as aggressive?
I'm assuming the bronze setup are the Volk ze40 18x10 +39. square setup 18x10 with 275/35?
Old Apr 1, 2025 | 03:01 AM
  #637
JT2MA71's Avatar
JT2MA71
If stock fenders, yes, the rear need some rolling or shaving with these Volk ZE40's in 18x10 +39 with 275/35 tires. And they are definitely more aggressive than stock.
Old Apr 1, 2025 | 03:05 PM
  #638
Defratos's Avatar
Defratos
Ok clear, thank you.
Old Apr 2, 2025 | 05:16 PM
  #639
JT2MA71's Avatar
JT2MA71
Old Apr 5, 2025 | 05:38 PM
  #640
Rossi's Avatar
Rossi
Installed this Super Now rear subframe bushing collars kit.
Rear mount before:
Rear mount after:
Front mount:
Ron, what is the advantage if getting these?
Old Apr 5, 2025 | 05:41 PM
  #641
Rossi's Avatar
Rossi
Made my engine cover 2-piece for ease of removal, without removing the shock tower brace.
Ron, how is the two-piece engine cover working out for you? What kind of hardware did you use and where can I get those? Thank you!!
Old Apr 6, 2025 | 10:03 AM
  #642
JT2MA71's Avatar
JT2MA71
Tightens up the factory rubber bushings for less movement.
Old Apr 6, 2025 | 10:07 AM
  #643
JT2MA71's Avatar
JT2MA71
It works perfectly! I just used some 3/16" aluminum, cut to strips of about 3/8" wide and 3/4" long. riveted on the rear half of the cover, flared the ends for easier line-up/guide for the front half.
Old Apr 6, 2025 | 02:21 PM
  #644
Rossi's Avatar
Rossi
Great, I will create something similar then, I just ordered new Tom's front strut bar and like your idea, thank you as always.
Old Apr 6, 2025 | 02:25 PM
  #645
JT2MA71's Avatar
JT2MA71
You're welcome!
