F&f height problem
F&f height problem
So I’ve recently bought coilovers for my car and I’ve mesured everything correctly but my front passenger side is lower than my driver side. I’ve raised that passenger side only too days after and still low rubbing hard sitting in fender not even a quarter turn. I want to keep raising it more but I’m afraid I’ll run out of thread because there’s already enough thread showing. I don’t know if the preload was adjusted by f&f but I’m afread to mess with the preload cause it void warranty. The rears however are the same measurement as the front and it **** a bit more high but I’m guess that the motor weight making the front lower too.
http://bcracingwholesale.com/index.p...ng-ride-height
As for your preload, I would remove almost all of it depending on how tight you have the spring. I typically start my preload a little snug, just enough so that the spring can still be rotated by hand.
thaiVo
10-22-18 01:42 PM
infate
Suspension and Brakes
12
05-15-13 01:18 PM
whiteivory
10-17-11 04:30 AM
soulific
16
02-14-10 08:40 AM
